Bad things happening to my truck
Old May 12, 2004 | 08:37 PM
KeukaZ71's Avatar
Default Bad things happening to my truck
here is a list of what i have been noticing this week that are all new:
1. oil looks like it is leaking from transfer case (WTF is up with that)
2. truck revved real high and didn't go anywhere (is my tranny going?)
3. truck goes in and out of OD at cruising speed (feels like TC engages and disengages)
4. feels like it might stall sometimes at idle or when coming to a complete stop (is it my plugs)
5. rear calipers might be sticking
Old May 12, 2004 | 08:47 PM
Wheatley's Avatar
Truck Sponsor
Man that sucks,I feel for you.It would drive me freakin crazy.I hope everything is ok
Old May 12, 2004 | 09:10 PM
XLR8NSS's Avatar
Adkoonerstrator
1. Pretty normal from what I've seen with just about any 4*4
2-3. Might be a torque converter issue. My old Y3200 went bad and would set a slippage code that unlocked the converter. I kept a laptop in the car to clear the code so I could drive normal until it set again.
4. Could be a gunked up TB or idle air control issue. Try cleaning up the TB with some brake cleaner and also take the idle air controller off the side and make sure it's not cruded up.
5. Might be the POS emergency brake. Wasn't GM fixing those things or didn't they have an upgraded part??
My one question. Have you been thinking of getting a new truck lately, if so your old truck knows and is doing this stuff on purpose, NEVER FAILS!
Good luck.
Old May 13, 2004 | 10:56 AM
creederado's Avatar
Time for the 2005 Silverado SS, Silver Burch Met with a power sunroof.
Sorry to here about your problems, It seems the better people take care of them the more they break down, Mine needs alot of attention and tweaking.
Old May 13, 2004 | 04:49 PM
KeukaZ71's Avatar
don't tempt me. the thought has crossed my mind plenty of times.
Old May 13, 2004 | 04:51 PM
KeukaZ71's Avatar
Good luck.
how did you know? i was considering a new truck lately.
thanks for the feedback. sounds like i don't have to worry about the transfer case problem. i'm hoping my tranny is not going as well. hopefully the ATF is just a little low in the tranny. i would hate for my TC to be going bad. as for the e-brake, i ripped mine out a few months ago. i think my calipers are sticking due to all the mud that accumulates there from offroading
Old May 13, 2004 | 05:16 PM
Hit Man X's Avatar
CHOP
Join the club.
Sorry about your troubles but I expect nothing less...vehicles have built in oblescense (sp?) where they are made to go bad after so long.
BTW...I'm waiting for an '05 also so I can get a sunroof in a 2500HD Dmax!
Old May 13, 2004 | 06:15 PM
XLR8NSS's Avatar
Adkoonerstrator
I'm telling ya, when you start thinking about a new vehicle stuff starts going bad on your current one. My dads truck KNEW he was getting a brand new Duramax tomorrow and the trans started slipping the other day along with the window going off track, fuel guage acting crazy, and a couple other little quirks. I don't know how cars know but, they do.
When you listed everything going wrong I knew you've been thinking about a new truck.
Damn, at least clean the mud off your truck after you dirty it up.
Old May 13, 2004 | 08:48 PM
KeukaZ71's Avatar
lol. ya, my truck must be possessed. that is true though about me thinking of a new truck, then all of a sudden freaky things start happening. it is almost like that problem we all have with our windshield wipers having a mind of there own.
ya, i get lazy after offroading and like to show off the mud. maybe i should buy an SS to eliminate that problem of having a tendency to go off roading. speaking of the SS. anyone have a pic of the SS in the birch or silver color that creederado mentioned earlier?
Old May 15, 2004 | 09:40 PM
yeary03SS's Avatar
If you took it to a stealership they'd probably tell you that you need $6,000 worth of repairs (i've had bad experience with stealerships). My 4wd is leaking where the output shaft bolts up to the axle. I've heard just changing the fluid can fix some small leaks. I'm sure it thins out over time like engine oil. I don't know much about t-cases.
