backup/reverse lights on in drive
Like the title says, my backup lights sometimes are on when I'm in drive. After searching here and google I still haven't a clue as to what could be causing this.
None that I know of.
Is the PRNDL switch a big dollar item? I might just start there and replace it. I'm not sure how long this has been happing. Two days ago a coworker told me about it, then I got pulled over on the way to work today.
I have a similar issue. While back my shifter became impossible to shift. Took it to a mechanic that was recommended to me and now my reverse lights dont come on when I put it in "R". I have to "play" w/ it a little going from "R" to "N" and then they will come on. It has to do w/ the either the switch as mentioned above or the shifter cable. Does your PRND321 always work according to what gear your in? Go from "P" all the way down to 1 and back up slowy. Mine usually works on the way down but will not make it all the way back up to "P" even though I can feel it shift in.
I cant tell you a fix as I never really paid attn to it but those are the 2 things I would look into. Mine still shifts properly and if I need some reverse lights I just hit the cargo lamp. Your situation sucks though. Hopefully you can get it taken care of.
Thanks. I think I need a new one though. I've tried adjusting it several times. Either the reverse works properly and I can't make it all the way down to 1 or I leave it as is and have all gears working
Thinking of one day getting a new one and a new cable. Guy I took it to mentioned he might have put in a cable from a diff truck. Not sure if they are different sizes but won't hurt to find out.
Thanks again
and OLD BULL sorry for the quick thread jack.
Thinking of one day getting a new one and a new cable. Guy I took it to mentioned he might have put in a cable from a diff truck. Not sure if they are different sizes but won't hurt to find out.Thanks again
