Back in action, Finally!!!
Old Mar 24, 2005 | 10:26 AM
12sec.5.3's Avatar
Default Back in action, Finally!!!
As of now, I have a freshly cleaned and rebuilt tt3000 and built 4l65e. Nice, crisp, easy shifts when taking off normal. Didn't mash on it yet cause I wanna make sure everything is working properly and gets well seated. Drove around last night testing it out and all seems fine. I have to get a couple things done after work and then test her out. I put 12 quarts of valvoline max life atf and it still needed more so I added 1 quart of chevron. I guess i'll have to check it again before i make a pass this evening.
Old Mar 24, 2005 | 10:36 AM
goshawk23's Avatar
Truck addict
good deal on getting back up and running. hopefully everything will go well for you.
Old Mar 24, 2005 | 10:48 AM
JERRY2500's Avatar
14 Second Truck Club
Cool, Maybe next wednesday i can watch it run at NPR. I'll even line up with you so i can get a good look at the back of your truck.
Old Mar 24, 2005 | 11:11 AM
12sec.5.3's Avatar
Yea, I'll try my best to be there. I'd like to check out the STS also.
Old Mar 24, 2005 | 11:13 AM
JERRY2500's Avatar
Hopefully i'll hit the 13's with all the extra's i've added and 10 psi boost.
Old Mar 24, 2005 | 11:16 AM
12sec.5.3's Avatar
Good luck. Did you go last night?
Old Mar 24, 2005 | 11:19 AM
JERRY2500's Avatar
No wound up working. And it would of been a good night to go too. Nice and cool.
Old Mar 24, 2005 | 11:21 AM
12sec.5.3's Avatar
Yep. The cool weather is almost gone now, though. I plan on putting cut outs back on my truck and should see some 12.9x's with good weather. I hope!
Old Mar 24, 2005 | 11:53 AM
Kano's Avatar
why did you change the PI?
how does it compare to the yank?
Old Mar 24, 2005 | 12:33 PM
12sec.5.3's Avatar
I didn't like the lockup of the vig. It sometimes took a long time to lock, + 0 towing capacity. Comparing the two, overall I rather the yank. Better driveability, more towing, fits my daily driving needs better. The vig. was awesome at the track and that's it. I'm happier with the tt3000.
