Arp stud heads
Old May 14, 2015 | 09:12 PM
Go5.3tt06's Avatar
Default Arp stud heads
I want to make sure if I understand from arp instruction since I have arp-ultra-torque-assembly-lubricants and thread sealer. So do first sealer in block from thread studs? Then mount heads on and use torq assembly lube on the washer and nuts on the studs? This is my first time own the arps. I am start apart heads this Saturday. Can't wait. Thank for help out
Old May 14, 2015 | 11:40 PM
GMCtrk's Avatar
NO thread sealer.
Install the studs hand tight into the block DRY.
Use the ARP assembly lube on the threads/washers/nuts when torqing to spec
Old May 15, 2015 | 04:32 PM
Go5.3tt06's Avatar
Why no sealer? Arp thread sealer came with.
Old May 15, 2015 | 05:00 PM
thunder550's Avatar
High on diesel fumes
Thread sealer is only used when the bolt holes protrude into the water jacket. They don't in the LS motors, so there is nothing to seal, no reason it use it.
Old May 16, 2015 | 12:13 AM
Go5.3tt06's Avatar
Oh I didn't know that. Old school motors I always do. But ls motors no need. Thank you. Start apart today. Can't wait.
thunder550
Oct 8, 2015 04:53 PM
greedygenius
Sep 3, 2015 06:51 AM
Yohns Kustom Fab
Aug 25, 2015 06:53 AM
JordanH
Aug 8, 2015 07:59 PM
ChevyLee
Jul 10, 2015 10:56 PM
