Anyone know...?
Old Sep 25, 2008 | 12:42 AM
whosdown's Avatar
Default Anyone know...?
is painting a stock bumper like the one below a good thing? does it flake off over time or anything?
Old Sep 25, 2008 | 12:48 AM
95 bright teal's Avatar
Do it! You need to clean them real well and use a good adhesion promoter and you should be fine im doing mine soon
and here is a good thread
https://www.performancetrucks.net/fo...d.php?t=424132
Old Sep 25, 2008 | 01:02 AM
here is one with more pics!
https://www.performancetrucks.net/fo...d.php?t=425310
Old Sep 25, 2008 | 01:23 AM
How do you go about painting the chrome section? I want to paint my front and back bumpers where there chrome, and leave the black plasic trim as is.
Old Sep 25, 2008 | 01:26 AM
it needs to be media blasted, you can paint it but it will chip for sure if you dont remove the chrome
Old Oct 4, 2008 | 07:14 AM
gmc6's Avatar
or you can sand it down to metal with a d.a. then primer it.
Old Oct 4, 2008 | 11:17 AM
Mangled03gmc's Avatar
Baltimore Whore
Yes it will work fine, good prep work is the KEY... Sand blast the chrome, sand the plastic parts, clean hell out of it with alky, thinner, use a good promoter..
John
Old Oct 4, 2008 | 11:43 AM
gtosilverado's Avatar
to paint a chrome bumper.......
1. wash it really good
2. sand it down with a 180-220 grit. this will aid in adhesion. wash it again.
3. spray about 3 nice coats of bulldog adhesion promoter.
4. spray it with primer surfacer.
5. wet sand the primer to get it as smooth as glass.
6. repeat steps 3, 4, and 5.
7. clean it really well with water and a rag. and let it dry off.
(1 more coat of bulldog, spray the sealer.... you dont have to do this, but i recommend it for better adhesion and better paint results)
8. if you dont use sealer,....spray one more coat of bulldog then paint and clear it.
if you do use sealer...... just paint and clear.
the better quality materials used, the better and longer the paint will look and last.
CJ Hungus
Apr 14, 2009 08:01 PM
Snacktime
Apr 7, 2009 06:27 PM
CHarris
Jan 9, 2006 01:43 AM
