another oil pump question
Old Nov 29, 2012 | 06:35 AM
  #21
b20forlife's Avatar
Originally Posted by TXSZ66AVLANCHE
Is there something preventing you from looking under the truck?
I was under the truck when I asked this cause the question cause the instructions I had said to remove it. But I figured it out. Have to disconnect my axles today cause after unbolting the diff it did not drop far enough to remove the oil pan. But after that I can install the new pump and start putting it all back together. And im just picking up new oil pan and timing cover gaskets just to be safe
Old Nov 29, 2012 | 07:34 AM
  #22
TXSZ66AVLANCHE's Avatar
The oil pan gasket is held on by rivets, make sure to grind it off before installing the oil pan.
Old Nov 29, 2012 | 11:28 PM
  #23
Sales3@Texas-Speed's Avatar
Truck Sponsor
Just drill out the old rivets, you can either put the new gasket on with or without riveting the new gasket to the pan.
Old Nov 30, 2012 | 09:12 PM
  #24
b20forlife's Avatar
got everything buttoned up tonight. i have 55 psi cold start and about 45 hot idle. and almost 80 at full throttle. im happy i did it my self but don't know if ill ever do it again. its a lot of work. thanks for everyone's help i appreciate it.
Old Nov 30, 2012 | 11:08 PM
  #25
Truck Sponsor
Good deal man, glad to hear that it worked out!
Old Dec 2, 2012 | 07:19 PM
  #26
Ferocity02's Avatar
Which o-ring did you go with?
Old Dec 2, 2012 | 09:34 PM
  #27
phasemaster1's Avatar
What determined the o-ring to use? Was it pick up tube, pump it self, or something else.
The_W
Oct 28, 2015 09:00 PM
Bluchevypick
Aug 18, 2015 09:11 AM
JordanH
Aug 8, 2015 07:59 PM
Ammadien
Jul 22, 2015 08:50 PM
Ferocity02
Jul 17, 2015 07:05 PM
