another oil pump question
Old Nov 28, 2012 | 11:09 AM
Ferocity02's Avatar
Originally Posted by b20forlife
Ok so I bought a melling m295 oil pump. Pretty much a stock replacement right? Also ut came with 2 different size orings. From what I read I want to use their green one right? Its smaller but thicker. Also I have a new gm red o ring. Can I use both the gm red o ring and the melling green one to insure that it wont break in the future? Also when I pulled out my coolant it was green shouldn't gm have the red coolant? And I bought new water pump gasket. Can I reuse my oil pan and timing cover gasket?
I would too like to know which o-ring to use in this situation. Gonna be putting in a Melling high volume pump soon.
Old Nov 28, 2012 | 11:39 AM
TXSZ66AVLANCHE's Avatar
On the pickup tube use the o ring that has the tightest fit. For the love of gawd don't try and use both.
Old Nov 28, 2012 | 11:46 AM
1FastBrick's Avatar
Custm2500's Rude Friend
I don't believe there is room for 2 o-rings. See which one fits the tightest when you slide the pick up tube in and run that.
Green coolant means some one changed it. The coolant is supposed to be changed or serviced at regular intervals. No one ever uses the additive for service they just change it. Green is usually cheaper.
Old Nov 28, 2012 | 01:11 PM
greasemykey's Avatar
I used the green one on my Texas speed ported pump.
Old Nov 28, 2012 | 02:13 PM
Sales3@Texas-Speed's Avatar
Truck Sponsor
There should be a sheet in the box with the melling pump that tells you what o-ring to use with your application.
Old Nov 28, 2012 | 04:18 PM
b20forlife's Avatar
Ok ill look in the box.
Also can I put some rtv on the oil pan gasket and timing cover to ensure proper seal?
Old Nov 28, 2012 | 04:30 PM
Ferocity02's Avatar
Only use RTV on the corners where the oil pan and front cover meet.
Old Nov 28, 2012 | 05:11 PM
99 2500's Avatar
I've found that reusing the oil pan gasket depends on luck, sometimes I got away with it and other times it poured oil out where the oil filter is mounted.
Old Nov 28, 2012 | 06:15 PM
b20forlife's Avatar
Does the oil pan bolt to the bell housing? Also do I need to remove starter?
Old Nov 29, 2012 | 05:56 AM
Is there something preventing you from looking under the truck?
