Alternator, old 105A is dying
Old Apr 21, 2010 | 11:07 PM
offroadrider12's Avatar
Default Alternator, old 105A is dying
My old one is on its way out, the volt gauge is fluctuating while driving and the lights are dimming. Truck said battery not charging when started up at first.
I currently have a 03 RCSB 2wd with a 5.3L and 105A alt.
I was hoping I could upgrade to the 145 or 130A model.
All I would need would be the AD244 alt (130-145A) and the serp belt for the higher amp alternator correct?
The alternators I was considering were:
Tuff Stuff 145A alternator from summit
http://www.summitracing.com/parts/TFF-8237/
or the 130A from DB Electrical.
http://www.db-starter-alternator.com...2005%20%208237
I am on a tight budget since I'm going to school still, I want something good an not crap.
All input is appreciated, thank you.
Old Apr 22, 2010 | 12:11 AM
Atomic's Avatar
I have a gauge for that
you dont need a new belt
Old Apr 22, 2010 | 12:24 AM
when I was looking on the parts website the 145A option uses a 93 5/8" belt while the 105A uses a 92 7/8" belt, so I was thinking I needed a longer belt, plus my serpentine belt is cracked anyway.
Old Apr 22, 2010 | 02:08 AM
99LsSilverado's Avatar
You can reuse the original belt but its really tight and puts alot of pressure on the other accessories.
Old Apr 22, 2010 | 09:46 AM
SILVERADO11's Avatar
Get your self the new belt and 145 amp and you will be happy!
Old Apr 22, 2010 | 10:11 AM
Bigredmariner's Avatar
Yes, get the new belt. The old belt may work if you force it on the pulleys but you will be stressing the hell out of it. Just get the correct length belt and be done with it.
Old Apr 22, 2010 | 10:22 AM
GMCtrk's Avatar
There was absolutely NO way my stock 105A belt was going to work with the 145amp alt. And it's been on there for 10 years, plenty stretched out.
Old Apr 22, 2010 | 10:31 PM
ok, thanks for the belt advice, but are the alternators I listed any good? or should I just get an autozone special with a lifetime warranty?
Old Apr 22, 2010 | 10:54 PM
Atomic's Avatar
Thats odd, my stock belt fit fine over my larger alt, still plenty of movement in the tensioner.
If you really want to save some cash look on car-parts.com for some local salvage yards for a 145 alt. I see them there from $50-$70.
Old Apr 23, 2010 | 08:39 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
thats what i did looked on car-parts.com
