Aftermarket Tachs mounting
Old Jun 19, 2007 | 12:27 PM
Silver-Dollar's Avatar
Why 4 cylinder? There usually already setup for 8. Some require cutting wires (mine has dip switches) for 6 or 4 cylinder modes. So are you sure that it needs to be 4 cylinder?
Old Jun 19, 2007 | 01:01 PM
thunder550's Avatar
High on diesel fumes
What's the advantage of running an aftermarket tach? Is something wrong with the factory one?
Old Jun 19, 2007 | 01:02 PM
silver-mod-o's Avatar
Hunt&Fisherator
Its VERY slow (mine is anyway) and with most aftermarkey cams etc etc, a lot of guys shift past 6K, and want to know where they are.
Old Jun 19, 2007 | 01:04 PM
vanillagorilla's Avatar
I wan't one that isn't slow, goes past 6000rpm and that has a shift light. The only problem is that they're usually 5" big. I think I'm just going to go with a shift light and use the tach wire mentioned earlier.
Old Jun 19, 2007 | 01:11 PM
Hunt&Fisherator
I'm going with one of these....
http://store.summitracing.com/partde...5&autoview=sku
everything, all in one. my 5" is going bye bye
Old Jun 19, 2007 | 01:23 PM
slow4.7on20s's Avatar
i took mine out for now and un hooked my gauges im getting all new phantom gauges and i held my tach in with double sided tape real thin and it never moved i didnt want to drill into the dash or pilliar
Old Jun 19, 2007 | 01:57 PM
I will be spinning past 6k. Check out the autometer 2302. 3 3/4" and has internal shiftlight
File Type: bmp
Old Jun 20, 2007 | 12:01 PM
RedHot04's Avatar
If it has a switch u should be fine. I did have to cut a wire on mine to set it as 4 cyl.because the 8 cyl. setup didn't work. Depends on the type of tach I guess...
and GM is wired a little diff. than other trucks.
Old Jun 20, 2007 | 08:11 PM
i had a auto meter monster tach with shift light and then my buddy had a proform tach the both had to be cut for 4 cylinder
Old Jun 21, 2007 | 06:28 AM
Did it not read in 8 cyl mode? Just curious so that I have something to help troubleshoot.
