Aftermarket Tachs mounting
Originally Posted by thunder550
What's the advantage of running an aftermarket tach? Is something wrong with the factory one?
I wan't one that isn't slow, goes past 6000rpm and that has a shift light. The only problem is that they're usually 5" big.
I think I'm just going to go with a shift light and use the tach wire mentioned earlier.
I'm going with one of these....
http://store.summitracing.com/partde...5&autoview=sku
everything, all in one. my 5" is going bye bye
Originally Posted by Silver-Dollar
Why 4 cylinder? There usually already setup for 8. Some require cutting wires (mine has dip switches) for 6 or 4 cylinder modes. So are you sure that it needs to be 4 cylinder?
and GM is wired a little diff. than other trucks.
