Advice on truck upgrades
Old Dec 10, 2013 | 04:22 PM
T.Ross's Avatar
Originally Posted by zero2sixT
IMO, the lower the better. Belltech is a good kit to go with. Probably springs, shackles, and hangers. Should look and ride good.
My truck right now is running ~2/4 drop. Its got 2" hotchkis drop springs in front. And 2" drop shackles in the back, with a leaf spring removed. 28" tires in the front, 29" tires in the rear. Probably went too short with the 28". Just didn't want to run a 10" wide tire up front. Going to add a knuckle up front and put my hangers on the rear. I added a pic.
I wouldn't say 4.8s and 5.3s are a waste of time. All depends on budget and goals, as mentioned earlier. I say get the stall converter and the tune first. Those two mods offer a huge bang for the buck. Then think about cams, heads, engine swaps, or forced induction.
thanks for all the info bro good stuff...I will keep this im mind...it seems like you have the same color as I have...whatvis that color called?
Old Dec 10, 2013 | 04:26 PM
T.Ross's Avatar
Originally Posted by TX Tahoe Z71
What are your goals and budget? A reliable daily driver that's fun, a 400hp street racer, or a weekend track machine with 10's or 11's in mind?
I would like a good dd at about 450 hp the budget is around 4000 but we all know how speed is....once you get the feeling you always want more...so its probably going to go up
Old Dec 10, 2013 | 04:29 PM
T.Ross's Avatar
[QUOTE=thegarrettgoines;5170559]It is a waste of time to throw boltons at and expect anything out of. I dont know what your goals are but if you want it to scoot without dumping 3k into it, swap it. 5.3's are alright but if your there you may as well get your moneys worth.[/QUOTE
I have a 5.3 im the garage...so you think I should swap it also ita an 03 also
Old Dec 10, 2013 | 04:32 PM
Koots's Avatar
Originally Posted by T.Ross
roll pan or no roll pan
I like roll pans for the most part, but on one hand, I like the functionality and protection of a stock bumper.
I've had the idea of maybe chopping the mounts and trimming the bumper to fit it tighter against the body, but that's a lot of work for little results.
If you absolutely want a rollpan though, get yourself one that can fit a rear hitch, then use a tow ball or plate in the hitch to protect yourself a little during a rear end collision.
Old Dec 10, 2013 | 05:51 PM
thegarrettgoines's Avatar
[QUOTE=T.Ross;5170747]
That or cam/spring/header it first...or sell it and buy a lq4
Old Dec 23, 2013 | 10:54 AM
Boost-freak's Avatar
sick setup , i like this drop
can you please offer part numbers or links for them
ARC
57
Feb 21, 2022 10:54 AM
wrb002
Aug 31, 2015 12:00 PM
Austino
Jul 30, 2015 03:28 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
