AC went out!!! Experts inside please.
Old Mar 12, 2010 | 09:03 PM
  #31
dlt76028's Avatar
Originally Posted by sixltrbtr
You need to check G102. It's a ground connection on the drivers side of the block. It should be at the same place the negative battery cable is bolted to the block. There should be two wires there. When did you first start having the problem?
This problem started right after I finished a head swap a few months ago. I just followed the negative cable to the block and there is one other cable hooked up with it.
Old Mar 12, 2010 | 09:04 PM
  #32
sixltrbtr's Avatar
Do this.. Jumper pin 30 and 87. Unplug the compressor and make sure you have voltage on the dk green wire. If you have an old head light you should connect the dk green wire to one leg of the head light and the other leg of the headlight connect to any good ground. If the headlight lights then you know that the power ckt can has voltage and can handle a load. Then connect one leg of the head light to the black wire at the connector for the compressor and the other leg of the headlight to the positive terminal on the battery. If the headlight lights your ground is good. If both of these tests pass your compressor should come on.
Old Mar 12, 2010 | 09:07 PM
  #33
sixltrbtr's Avatar
Put a socket on the bolt for that ground and make sure it's tight. Better yet unbolt it and make sure it's clean and there isn't any corrosion on the terminal then bolt it back up and make sure it's snug.
Old Mar 12, 2010 | 09:09 PM
  #34
sixltrbtr's Avatar
I sent you a pm of a diagram.
Old Mar 12, 2010 | 09:13 PM
  #35
Mangled03gmc's Avatar
Baltimore Whore
Who needs AC, I took my belt off..
Old Mar 12, 2010 | 09:15 PM
  #36
sixltrbtr's Avatar
Not everybody be ridin dirty haha.
Old Mar 12, 2010 | 09:18 PM
  #37
Baltimore Whore
Yah well thats how we do in B more, well Key West now Yah I should be out, but it is storming like *****
Old Mar 12, 2010 | 09:19 PM
  #38
dlt76028's Avatar
You may have just lost me on this one, but I'll try tomorrow in the light.
I'll check it tomorrow in the light. Since the battery works though, shouldn't it be a good ground?
We live in TX, get out of my thread
Old Mar 12, 2010 | 09:26 PM
  #39
sixltrbtr's Avatar
The light is to check to see if the wires and connections can carry a load. It's kinda like a voltage drop test. Just because a wire has 12v on it doesn't mean it can turn your starter motor over or in your case turn you compressor clutch on. If the wires can power on a headlight you should be good. How did you hook you compressor up to make it come on?
Old Mar 12, 2010 | 09:31 PM
  #40
Baltimore Whore
))))00000000))))) When dis sixltrbtr move to TX?? Texas FTMFL
