AC went out!!! Experts inside please.
#21
ok cool compressor is goodok check voltage at the relay terminal for 12 volts if you have voltage then jump out the relay and see if the compressor comes on
#26
You should have voltage at 86 and 30. the computer grounds pin 85 to energize the realay witch connects 30 to 87 and turns on the compressor. Make a jumper to go between 30 and 87 and the compressor should turn on. That will tell you at least that much is working. If it comes on the computer isn't sending a ground signal to pin 85 for some reason. Let me know what you find. Oh make sure you plugged the compressor back in from where you were testing it before for this to work.
