AC went out!!! Experts inside please.
Old Mar 10, 2010 | 04:03 PM
dlt76028's Avatar
Angry AC went out!!! Experts inside please.
My compressor just all of a sudden stopped turning on. I went to get it charged and they said it's not taking in any coolant? I checked all the fuses/relays in the truck and under the hood and they're good. What else can I check? It's starting to warm up here in TX
Old Mar 10, 2010 | 04:09 PM
lablackbeast's Avatar
doesn't know what quit means
i can get you everything if you want from an 03 truck (idk if they are different) let me know
Old Mar 10, 2010 | 04:14 PM
Badboy464's Avatar
there is a inline filter in your system and it could be clogged from metal shavings. The people working on your truck should have checked that tho.
Old Mar 10, 2010 | 04:33 PM
blackbeast ss's Avatar
turn your ac on and check if the clutch is energizing with a volt meter should have 12 volts if you got voltage on the compressor and compressor is not pumping then its a failed compressor or clutch.. need to replace
if you dont have 12 volts at the compressor then it could be (1) fuses
(2)low charge very common problem, refrigerant is low the system is equipped with a low pressure switch witch means if the system is low on refrigerant it will kill 12 volts to the compressor to protect it,sometimes you have to jump out the switch to charge the system(3)could be a bad switch the one that turns on the ac
Old Mar 10, 2010 | 04:41 PM
53bowtie's Avatar
In my experience if the compressor is not locked up it is usually the low pressure switch located on the dryer/evaporator under the hood. You can unplug this switch and jumper it to see if the compressor kicks on or not to narrow down the problem. Also, if the bottle of R134-a is large enough (we use 30lb bottles) and has enough gas in it then it should have enough pressure to push the gas in without the compressor having to be on so I dont know what they mean by "its not taking a charge" unless they are using those little cans.
Old Mar 10, 2010 | 04:45 PM
BlackGMC's Avatar
Resident Retard
+1 on the low pressure switch..
Old Mar 10, 2010 | 05:03 PM
their called beercan tech dont have a clue of how hvac systems work.i been in the hvac field for about 10 years now and you wont believe the crap work i seen form some techs out here
Old Mar 10, 2010 | 06:01 PM
dlt76028's Avatar
How and what sensor do I check for the clutch?
How do I jump the sensor to bypass the switch?
Thanks for the answers guys, I can't stand electrical problems... And FYI I tried turning the compressor on with my EFI LIVE, and it still didn't come on.
Old Mar 10, 2010 | 06:06 PM
00ChevyScott's Avatar
Wearin' da big hat
Pull out the plug on the pressure switch that goes into the dryer bottle on the firewall. Use a paper clip to jump the two pins in the connector and see if that causes the compressor clutch to engage. If it does, you either have a bad switch or are low on coolant. The system might not be taking in coolant because it of a bad/clogged valve or a clogged a/c filter. You need to find someone with a set of manifold gauges (who knows how to use them) and do some trouble shooting.
Old Mar 10, 2010 | 06:08 PM
dlt76028's Avatar
EDIT I just pulled the plug and jumped the sensor, and the clutch didn't kick on.. What does that rule out?
