ABS Parking Brake Problem?
Old Oct 14, 2007 | 01:59 PM
Chevy Cowboy's Avatar
Piss Pumps for Sale
From: Moncton, New Brunswick, Canada, The True North Strong and Free!
Default ABS Parking Brake Problem?
Ok So today I went into town to pick up a few things, anyways I was on a slight hill parked so I put down the parking brake as far as it would go, mine goes right to the floor and its always done this since I had it, but a new problem I start the truck put it into drive and drive less then a foot and I remebered the parkign brake was on so I pulled the realease and the pedal came back up all the way, but now whenever Im driving around the abs and parking brake light flash on for a second or 2 then flashes off then on again etc, sooooo question is what the hell did I do?
Old Oct 14, 2007 | 03:39 PM
TylerCustoms's Avatar
the e brake could just be hung up slightly...it doesnt take much to flash that light, ride down the rd for like a quarter mile with the e brake on a little bit then release it...might fix the hang up...just my .02
Old Oct 14, 2007 | 03:40 PM
nightrunner's Avatar
Mr. Obvious
make sure the ebrake pedal has come up all the way, also make sure your abs sensor is still plugged in
Old Oct 14, 2007 | 03:51 PM
Piss Pumps for Sale
guy on fullsize chevy said it was probably my ebcm, where is the abs sensor?
Old Oct 14, 2007 | 03:52 PM
Mr. Obvious
on the wheel hub
Old Oct 14, 2007 | 03:54 PM
Piss Pumps for Sale
front or rear? or all 4 corners?
Old Oct 14, 2007 | 03:59 PM
Mr. Obvious
all 4 i think, i know for sure they are on the front
Old Oct 14, 2007 | 04:00 PM
Piss Pumps for Sale
ok thanks ill go check right now
Old Oct 14, 2007 | 04:06 PM
Piss Pumps for Sale
abs sensors are still plugged in, ebrake pedal is all the way up like it should be, got the computer scanned said something about an eratic rear wheel speed sensor, tech said there is probably something like broken wire or something in the electrical system
Old Oct 20, 2007 | 02:59 PM
Piss Pumps for Sale
Saweeet found the problem all fixed and good to go!!! lol should check the ground wire alonngggg time ago, thanks for all the help fellas!!
blowngmc
32
Oct 12, 2017 11:59 AM
2004gibbstruck
Sep 7, 2015 06:05 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
Alco
Sep 4, 2015 04:08 PM
