ABS light = blown 3rd brake light
Old Apr 19, 2016 | 10:04 AM
GM1697's Avatar
Default ABS light = blown 3rd brake light
So is this real??
ABS light occasionally started lighting up on starts, would go off after driving for a second. Would also occasionally blip on and ding while driving, immediately going off afterwards.
Turns out my 3rd brake light was blown. I read somewhere that this would trip the ABS light. Is this true?? Anyone else have an experience like this??
Old Apr 19, 2016 | 10:15 AM
Vortec350ss's Avatar
Rings a bell now that you mention it.
Old Apr 19, 2016 | 11:26 AM
Atomic's Avatar
I have a gauge for that
Eh, sounds fishy.
Check your speed sensor wires by your wheels. I had an issue with my other truck that the wire was rubbing on the wheel and eventually wore through the insulation and was shorting on the wheel.
Old Apr 19, 2016 | 11:57 AM
GM1697's Avatar
I will investigate this weekend, figured I might as well check the wheel bearings
Old Apr 19, 2016 | 02:35 PM
Why dont you just replace the bulb and see if the problem goes away. It'll take 5 minutes.
Old Apr 19, 2016 | 09:18 PM
GM1697's Avatar
I did replace the bulb cowgirl. It hasn't happened since. But that's only 24 hrs ago.
Old Apr 19, 2016 | 11:11 PM
Richardman1992's Avatar
I've read that this can be an issue on f-bodies lighting up the abs code, but not on trucks. Lots of people talked about it on ls1tech
Old Apr 20, 2016 | 01:40 AM
Suburbazine's Avatar
If the ABS light is on you need to run down to the parts store and see if their code reader can do ABS on your truck. On a truck the 3rd brake light cannot set an ABS code, it is independently wired to the brake pedal.
Blip and ding is usually a bad ground for the ABS unit.
Old Apr 20, 2016 | 07:43 AM
Sounds like thats a trust worthy answer above.
Old Apr 20, 2016 | 08:59 AM
GM1697's Avatar
The ground near the drive side body mount?
