97 tahoe 5.7
Old Aug 10, 2010 | 08:21 PM
mhotrodscooter's Avatar
Default 97 tahoe 5.7
My tahoe is acting crazy! Sometimes when I let off the gas it dies & sometimes it won't start without giving it gas! It was parked up for almost 3 years before I got it. I don't have a clue what's causing this. I've change the plugs, cap,rotor & wires! It doesn't throw a code either! So a little help please!
Old Aug 10, 2010 | 08:58 PM
bai78's Avatar
bad gas??? flush the fuel lines.....I dunno, just throwing it out there.
Old Aug 10, 2010 | 09:02 PM
Well thanks! I've changed the fuel filter twice hoping to see something nasty inside but clean as a whistle
Old Aug 10, 2010 | 09:05 PM
bai78's Avatar
How about dying fuel pump? bad regulator? clogged poppets?
Old Aug 10, 2010 | 09:10 PM
2005 Silverado's Avatar
SPAM HUNTER
Fuel pump have good pressure? Maf clean?
Old Aug 10, 2010 | 09:13 PM
Just asking but wouldnt that effect wot 2? It runs good going down the road! just once in a blue moon she'll die when you let off same as for starting it 2!
Old Aug 10, 2010 | 09:18 PM
Haven't checked the pressure! I clean the maf & tb when I changed all the plugs & stuff!
Old Aug 10, 2010 | 09:34 PM
bai78's Avatar
Over time the pigtail will corrode. This was the case with my pump when I switched it out for the Racetronix/Walbro.
Also, another thing to check would be the starter. Those wires corrode as well which would cause it to die or hard start.
Both things have happened to me. It is a 13/14 year old truck that has been sitting without TLC. Just throwing it out there.
Old Aug 11, 2010 | 08:13 AM
Thanks man for the info! I'll check the fuel pressure next time it does it & hope it something simple as the fuel pump!
Infernohoe
48
Oct 2, 2015 10:25 PM
mitchellmade
Sep 27, 2015 08:27 PM
project-pegasus
Sep 18, 2015 08:22 PM
FormulaZR
Sep 14, 2015 05:23 PM
