706 heads coolant fix?
Thanks for the info. Ill just have to see what she wants to do. If I replace the heads I would want to put lifters in it too because it has a tick also. What's the best way to clean under that valve covers before I use the stop leak if I do that.
How much coolant is it using? If it's castech heads, it will be a slow loss. The crack in the head doesn't leak very fast. If it's bad head gaskets, it will be a lot faster and get progressively faster. I had castech heads, thought I had a crack, turned out to just be bad head gaskets.
