6.0 bolt up
Old 06-22-2017, 08:12 PM
Registered User
melodynpepper's Avatar
Default 6.0 bolt up
2000 Silverado-swapping out 4.3 for a 6.0. the truck is a five speed manual with 4 wheel drive. Does anyone know if the 6.0 will hook up to the factory 5 speed?
Old 06-23-2017, 07:31 AM
firebladeJJ's Avatar
depends on if you have the long or short crank on the 6.0, 99-00 lq4 engines had a long crank, didn't need a spacer to mount to the NV3500, outside that year range, you'll need a spacer.
Old 08-15-2017, 07:18 AM
tpartsman's Avatar
Default this is exactly what I am saying
verbatim @ peppernmelody
Old 08-15-2017, 07:25 AM
tpartsman's Avatar
Default get her done
https://www.novak-adapt.com/
Exactly what he said: Here you can get a flywheel to make it happen other wise
hope you have a long crank and get a flywheel off a 4.8 99-00 1500 ( GM parts# 12561755) or find a flywheel from 99-00 2500 6.0 (GM PART # 12561757) manual trans. Oh yeah and your going to need the bolts with the flywheel.
Old 08-15-2017, 07:35 AM
tpartsman's Avatar
Default here is some info
Here is a place showing one used Kentwood Auto Salvage 877-660-2502
MrHorsepowerLSx
07-11-2017 09:11 AM
bttlfed98gt
12-08-2016 12:51 PM
lsm
11-04-2016 08:43 PM
slamm69
10-21-2016 07:21 PM
slamm69
10-20-2016 07:56 PM
Quick Reply: 6.0 bolt up
