5.7 For 5.3
Old Jan 31, 2005 | 02:25 PM
redwagon63's Avatar
Default 5.7 For 5.3
Can A 5.7 Ls1 Be Swapped For A 5.3 With Little Trouble?
Old Jan 31, 2005 | 02:42 PM
goshawk23's Avatar
Truck addict
are you asking can you install a ls1 5.7 to replace the 5.3? if so the answer is yes. I dont' think there is that much trouble in doing the swap. however, there are some guys on here that have done it.
Old Jan 31, 2005 | 02:45 PM
quicksilverado's Avatar
Will swap with no problem. Take the intake, oil pan and all the accessories off the 5.3 and put them on the 5.7.
Old Jan 31, 2005 | 06:37 PM
Yes. most guy's stay with the ls1 intake and modify the larger Ls1 fuel rails to fit. Saw that trick on amy's 12.1 sec rcsb . More power less weight how can that not be good.
Old Jan 31, 2005 | 08:12 PM
Zick's Avatar
If you kept the LS1 manifold, why would you have to modify the LS1 fuel rail to fit
Old Feb 1, 2005 | 01:32 PM
Zick's Avatar
I'm looking at maybe picking up an LS1 here pretty soon and had a question;
Should I, swap the 5.3 intake and heads onto the 5.7 block or leave the whole 5.7 setup the way it came from the factory? Just wondering what would make better power.
Also if I leave the 5.7 the way it is, I can still use my 02' 5.3 PCM with it just have it recustom tuned correct?
Thanks
Old Feb 1, 2005 | 08:09 PM
ktmrider's Avatar
Thanks
Unless you get the entire front accessory drive unit from the LS1 ( basically the complete motor including intake ) you will need to use your intake and acc drive system as they are inherently different due to intake rise, water pump outlet, etc. The LS1 intake makes a TINY bit more power up top but is worse everywhere else compared to the truck intake. Absolutely no difference worth swapping for.
The stock PCM will drive the 5.7L engine just fine for starters. I would eventually get a retune to realize the full power potential tho.
Again, overall an easy swap.
TAPyvehc93
Dec 27, 2015 12:14 PM
pewter00
Sep 14, 2015 09:17 PM
sTNT971
Sep 11, 2015 02:38 AM
11MPG
Sep 10, 2015 08:34 PM
11MPG
Sep 8, 2015 04:52 AM
