5.3 w/pushrods and rockers
Old Aug 12, 2006 | 07:44 PM
Supertrux's Avatar
Default 5.3 w/pushrods and rockers
what effect would one expect after installation of hardened pushrods and 1.8 roller rockers on A 5.3l? Can this be done without a tune?...and would there be any adverse affects?
Old Aug 13, 2006 | 03:51 PM
Supertrux's Avatar
no comments from the boards with its infinite wisdom....?
Old Aug 13, 2006 | 04:34 PM
RoninsDenali's Avatar
Pushrods (7.400") will not effect the tune at all.
1.8:1 ratio rockers will however. And unless you are getting those for a complete steal. I would highly recommend against rockers. They seem to cause more trouble with the valvetrain then the power they produce. They will net you maybe 10hp and given their cost you would be much better spending your money on a good tune or some other bolt on.
I guess i could sum up my opinion on 1.8 rockers as CON > Pro...
Old Aug 13, 2006 | 04:57 PM
Okie5.3's Avatar
there shouldn't be any adverse effects if the springs can handle the slight increase in lift, the pushrods are of the correct length, and proper lifter pre-load . a tune isn't required, but as always it would optimize the setup.
mikeyjm1
17
Oct 29, 2015 11:04 PM
chvy=power
Sep 8, 2015 11:06 AM
superchomper2003
Aug 26, 2015 09:39 AM
JordanH
Aug 8, 2015 07:59 PM
BigEd_72455
Aug 8, 2015 07:37 PM
