5.3 oil leak
Old Nov 19, 2013 | 12:49 PM
dunegoon112's Avatar
Default 5.3 oil leak
Got a 99 z71 with the 5.3 recently started leaking oil from what I thought was the rear main but it's not pulled the flywheel inspection cap and all down inside there is dry. The drivers side valve cover is pretty nasty but I don't think it's leaking any other ideas? Seems to be coming from drivers side
Old Nov 19, 2013 | 05:06 PM
Beatdown Z's Avatar
Laid Back
Oil pressure sending unit.
Happened to my brother's '00 4.8 and his '03 6.0.
Old Nov 20, 2013 | 08:36 AM
Thanks For the info I'll have to check that!
Old Nov 20, 2013 | 08:58 AM
06murder's Avatar
get some brake cleaner or purple power and clean egine, turn the truck up an look for the leak best way to do it ,then just guessing
Old Nov 20, 2013 | 09:47 AM
mattjones's Avatar
i went through this checked all the above listed things. turned out my valley cover bolts under the intake manifold lossened up and was coating the valve cover as well as a ton of other stuff. im not saying thats the problem but give them a check. i replaced the valve cover gasket the olipan gasket and the sensor on the back of the block before i found it. hope this helps
Old Nov 20, 2013 | 02:50 PM
Whoa I didn't even know that was possible thanks for the info
Old Nov 20, 2013 | 03:54 PM
Beatdown Z's Avatar
Laid Back
Interesting info mattjones. I'll be checking that next on my brother's truck, since it still has a minor leak.
B.love18
Sep 21, 2015 08:31 PM
Mossyoakglock
Aug 28, 2015 12:49 PM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mzay
Jul 6, 2015 11:03 PM
