5.3 differences by year?
Old Aug 18, 2011 | 06:09 PM
operatorfailure's Avatar
Default 5.3 differences by year?
Does anyone know what changed from 1999 to 2000? I believe they went from 270 to 285 horse and can't find out why.
Old Aug 18, 2011 | 07:53 PM
Just found it was injectors, is it worth it to swap in some 2000+ injectors and I'm guessing a tune will be needed with them right?
Old Aug 19, 2011 | 02:56 PM
Coban's Avatar
It wasn't injectors.
At one time they changed to high flow catalytic converters and also changed cams at one point.
Old Aug 22, 2011 | 03:51 PM
hog's Avatar
hog
PCM tuning mainly.
In 2000 GM was using 2 different injector sizes, manual transmission trucks in 2000 and all 2001+ trucks used the larger 25 lb/hr injector while all 1999 trucks and 2000 auto trucks got the 22 lb/hr injector.
1999 LM7 5.3 was 270hp/315 hp, 1999 L31 5.7 was 255hp/330 lb/ft.
2000 LM7 5.3 was 285hp/325 lb/ft.
1999/2000 4.8/5.3/6.0 cam specs
190/191 duration, .456/.465 lift, 114 LSA, 112/116 Timing
2001 6.0 switched to the 196/207 duration at .050 0.467/0.479 lift on a 116 Lobe center which was also used in the 01+ LS1.
peace
Hog
Old Aug 22, 2011 | 04:17 PM
Thanks hog!
So I'm guessing just get the new injectors and tell whoever tunes it to update the tune for the 25 lb injectors and I will be in business.
Choda
Jan 22, 2026 02:03 PM
ferrellrooster
Mar 6, 2025 03:22 PM
pjb1972
Sep 17, 2015 02:06 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
smit2732
Jul 19, 2015 01:43 PM
