5.3 and 6.0 intake manifolds the same?
Old Nov 4, 2008 | 06:31 PM
colekill's Avatar
KickinAssAndTakinNames
Default 5.3 and 6.0 intake manifolds the same?
are they interchangeable, the same, would the 6.0 manifold be better on a 5.3 motor, are cable TBs interchangeable with the drive by wire TBs.
Old Nov 4, 2008 | 06:39 PM
Stoichiometric's Avatar
Manifolds are the same. To change throttles you would need the ETC pedal, tac module, operating system (?) and throttle. It may be tied into the BCM also.
Old Nov 4, 2008 | 06:44 PM
Mangled03gmc's Avatar
Baltimore Whore
DITTO
John
Old Nov 4, 2008 | 06:59 PM
colekill's Avatar
i dont want to switch to drive by wire. i want to get a stock manifold without the big egr hole on the side like my current one has(when i took the egr off i put a pipe plug in the hole). just wondering if i bought someones manifold that came with a wire tb, or off a 6.0, if i could bolt my cable tb to it no problem.
Old Nov 4, 2008 | 08:41 PM
white1's Avatar
Yes, everything will work
Old Nov 4, 2008 | 08:47 PM
GMCtrk's Avatar
You can get a block off plate for the EGR from GM. It retails for about $20.
Old Nov 4, 2008 | 09:31 PM
colekill's Avatar
skeet wants to sell me a tbss intake. any thoughts?
Old Dec 14, 2021 | 12:27 AM
Rafaele1221's Avatar
Registered User
so did you ever find out if the 6.0 intake manifold fits the 5.3
Old Dec 14, 2021 | 12:48 AM
RedXray's Avatar
100% Redneck
Yes it's exactly the same part
Old Dec 14, 2021 | 07:05 PM
adriver's Avatar
The TBSS intake is the only unique cathedral port truck intake because of a 90mm opening. All the rest of the gen IV truck intakes are 87mm opening. The gen IIIs are 78mm.
Sereno
Mar 20, 2021 12:29 AM
PSM
24
Aug 23, 2008 11:46 AM
TroubleRado
Mar 31, 2006 12:15 PM
m8w6r77
Jan 19, 2006 02:49 PM
01Blackerado
53
Apr 2, 2004 02:53 PM
