4L60E swap to 4L80E need info.
Old Feb 2, 2006 | 12:20 AM
Silent Thunder's Avatar
Default 4L60E swap to 4L80E need info.
Going to go with a 383 and I want to get a 4L80E trans. Will it bolt in place of the 4L60E? Will I have to mod the drive shaft or anything? Any help would be gre8t
Old Feb 2, 2006 | 12:25 AM
thunder550's Avatar
High on diesel fumes
What year is the new motor? What year truck is it going in to?
You will probably have to use a crank spacer for the flywheel, a wiring harness adapter, a shorter driveshaft, a new (or modified) crossmember. Fluid lines will also have to be modified. Speed Engineering (sponsor) has a kit that you can buy for the conversion http://speed-eng.com/store/index.php?cPath=23_940_1409
You will also need a tune update.
Old Feb 2, 2006 | 12:43 PM
It is going into a 96 GMC 1500 Ext Cab. I will have a 1 piece rear main seal 383 stroker.
Old Feb 2, 2006 | 01:57 PM
thunder550's Avatar
Oh....then I guess I can't help you, sorry....hopefully someone else will respond shortly.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
chadjcompton
17
Jun 21, 2022 08:47 PM
XL7
May 5, 2022 01:48 PM
lycominghunter
Jul 29, 2015 04:24 PM
alex226
Jul 16, 2015 10:55 AM
