4.8L what is its potential?
Old Mar 28, 2023 | 11:02 PM
  #21
RDF1's Avatar
DuNnO
5 Year Member
Originally Posted by Snooter1969
Best cam duration to wake up lower end torq for 4.8?
Twin Screw Blower... TVS1900 or so.
Your not going to get more low end torque from a cam that is larger than stock in a 4.8.
I just dynoed a stock 2003 4.8 the other day. 2000rpms it made something around 220ftlb tq and 89hp. Going up in cam size will only shift the hp/tq curve up further into the rpms not lower rpms.
Old Mar 29, 2023 | 12:32 AM
  #22
adriver's Avatar
A better question would be: how many pickles can you pull out of a frog's ***?
Or,
How many pancakes does it take to shingle a roof? (Purple, snakes don't have armpits)....... (It's not my fault you're not on shrooms or cid).
Go start your own thread, but a cam won't. Your closest options are swapping to 5.3 internals, a 6.0 swap, FI, or 4.11 gears. There is no cam, and there is no easy or cheap answer.
Old Mar 30, 2023 | 02:57 PM
  #23
RB04Av's Avatar
5 Year Member
It has the potential to be thrown away and replaced with something better, with very little effort required
Fugheddaboutit
The real little "truck torque" cams, 206° absolute max on the intake, are the only ones that won't hurt it too much. 200° would probably be better. A small motor like that doesn't max out the exh port flow, therefore doesn't need much, if any, duration split. A tight LSA like 110° will help. Don't expect miracles
Old Mar 31, 2023 | 09:05 PM
  #24
68Formula's Avatar
Like RB04Av said, either BTR Truck Torque or SUM-8727R1,
slick_sierra
31
Jul 5, 2015 10:45 AM
CHEVRACER83
14
Aug 25, 2006 05:30 PM
TigerFan187
27
Jul 9, 2006 01:53 PM
2003Silvyrado
Sep 16, 2004 12:29 PM
2001CamaroGuy
May 9, 2004 10:17 PM
