4.8 to 6.0 swap. O2 sensor question
Old Mar 8, 2019 | 10:59 AM
Bwmcbe's Avatar
Registered User
Default 4.8 to 6.0 swap. O2 sensor question
Swapping a 6L 4L80e into my 05, I got the o2 sensors off the 6L donor truck cause I knew the plugs were different than my 4.8. Question Is, do I need to use the 6L sensors or can I just keep the 4.8 ones? I was planning on keeping the original harness in the truck but I do have the donor harness aswell. Will also be running a 6L pcm. I do have hp tuners aswell. Thanks guys
Old Mar 8, 2019 | 12:23 PM
Merctech2's Avatar
Just swap the long block, use everything from the truck gonna tune it anyway. That’s what I did and did the repin for the trans and segment swap.
Old Mar 8, 2019 | 01:37 PM
RedXray's Avatar
100% Redneck
The 4.8 o2's will work with the 6.0 swap.
I went from a 4.3 to 6.0 and used the original 4.3 o2's
Old Mar 8, 2019 | 05:48 PM
RB04Av's Avatar
5 Year Member
O2s don't care about the engine size. As long as the connector hooks up you're good to go. In this case, leave the 4.8 ones in there; if you were swapping harnesses too, you'd use the 6.0 ones.
TAPyvehc93
Sep 17, 2015 10:10 AM
O3GMC
Dec 26, 2003 12:54 PM
bigblue4x4
Dec 5, 2003 08:31 PM
