2006 RCSB 4x4 V6 to V8 LQ9 Cammed Manual 5 Speed Swap
#42
Ill just dump my part numbers best I can, no particular order. Good luck with your swap! And ill let you know where to send beer money for this cheat sheet!
Nv3500 transmission # 12572825
Flywheel 6.0L #12561680
Flywheel Bolts 6x 12563485 (long ones 29mm over 23mm flex plate)
Pilot #12557583 (Comes with Luk Kit)
Slave Cyl #20958083
LuK 04-201 New Clutch Set 6.0L Clutch (Told its same as OE)
T Case Gasket #24245110
Chevy NP261 NP263 Transfer Case Input Shaft, 32 Splines, 42740
as 4l60e is 27 spline
Steering column Cover # 26089146
Engine Mount Frame 4x4 R # 15113847
Engine Mount Frame 4x4 L # 15113849
Engine flex mounts 2x #15226254
TRANS Cross Member # 15040432 FYI didn't need this due to the 4L60e Dont get it unless your running another trans, or perhaps 2wd cross overs need it
Shift Lever # 15041067
Shift Lever Boot Retainer # 15711231
Retainer Plastic Pins # 10146315 (Didn't Use, just bolted in)
Shift Lever Boot #15711228
Shift Lever Foam #15033964
Clutch Pedal Related
Clutch Pedal #15027983 (I hear there is a corrected number for a low pedal, or is this the master cyl is diff?, I had to add a spacer to this one)
Master Cyl #24235619
Bolts for Bracket #11517182
Brake Pedal #15097182
Weld in clutch pedal bracket (where the 3rd bolt sits above the pedal) #15713209
Rad Related (Swapped to manual 6.0L Rad)
GM OEM-Radiator 15841575
Vent Hose #15020224
Lower Rad Hose #22827735
Upper Rad Hose #15179498
Rezy Inlet Hose #15170551
Heater Hose #15792821
There is another one somewhere??? or that might be it
Random
GM 6.0L V8 Dipstick & Tube (12622055 12563918) to clear headers
Serpentine Belts
#12637204
#12576447
AC Compressor # 25891792 ACDelco 15-20941 (engine was from wrecker and had a crappy looking random ac pump on it)
AC Lines
#22876350 ACDelco 15-34531
#22876357 ACDelco 15-34528
Had to use a 2012 Accumulator as the 4.3L AC accumulator doesn't fit
A/C Accumulator ACDelco GM Original Equipment 15-11061
T56 Backup Light Connector Wiring Pigtail GM LT1 LS1 Lamp Transmission
06-07 Chevy Truck LS1 LSX Gas Pedal Accelerator Drive By Wire TAC Module
GM STARTER SHIELD BELLHOUSING #12561536
Water Pump Gaskets #12630223 Change the pump on any engine sitting for some time
Brake booster line was different too...
#44
So after showing the shop that rebuilt the case the concern on a test drive they asked for the transfer case out as I dropped it off that way during my build, no problem. They then informed me very non-informatively no major issues and its ready for pickup in a few days, commenting on loctite used now and such and such. I didn't believe anything was done as I had a chain skipping noise, and no way was I installing it again to have the same problem.
I decided to get a GM rebuild at this point as they could have one in that day, Got a NP261 HD, increasing the rating considerably from my bastardized 261 with a 32 input installed so no should be no more issues now with the 261HD.
This new T case once I got it in this last weekend runs quieter and no exit shaft play making clunking noise when you tug up and down on the rear drive shaft. and the noise is gone under hard throttle.
I am assuming it was chain skipping, cant be sure if it was the shops rebuilds fault or bad parts. They made a deal of full refund if they get the case, so since it was full of metal I took that deal and lost my core.... lose lose I guess.
Anyways shes driving better than ever now! Pulls GOOD!
#47
Update!
Not sure if I mentioned yet but she now has 3" SS Exhaust to the back. Got a Magnaflow kit from Y pipe back.
Had to modify from the muffler provided as the 18" SS it comes with was bad drone on the highway, also Nascar like sound on throttle. I installed Magnaflows largest Muffler a 22" with a small cut in the kit. Seems far better now and still sounds nice on throttle.
Next is I installed a Eaton true track as I got tired of excessive 1 wheel peel, and figured I would drive on pavement in 4x4 less / take some stress of the front 4x4 system with it installed.
Works great, did a 6 hour 4x4 trek up the west side of Harrison lake here a month or so ago and lots of traction, only needed 4x4 for the sketchy parts.
Ha-vent tried a short throw or a core one, I looked those up though seems nice, on the shifting topic seems like the gates are pretty shut if your in a rush above 6000 in this transmission, you need to give her a half second for rpms to drop.
Also as per Slick Sierras comment I know its a mild cam, I still wanted it to behave in the bottom end with plenty of pep, pretty happy with it, but some times I do wonder how hard it would pull in the top end with something more aggressive.
I hope to get out to the track and see what she runs this month or next.
Also Great shot from the East side of Harrison last weekend.
Cheers
Cheers
#48
Beautiful truck and beautiful view! Nice to see someone with a 4x4 that hits some dirt! I just killed my second rearend so now that you have a tru trac be careful during long straight burnouts any wheel hope and your screwed!
You should post a sound clip if you can I desprately need to quiet mine down.
#50
Engine swap
How is it going? I have a 2005 silverado 4.3 vortec, lately its being giving me alot of problems it has 242,000 miles so its undestandable. And now I've been thinking about getting an engine swap i wanted a 5.3 or a 5.7. Would you by any chance know what i need for the swap and how much money would i need? Thanks
