2 question: New Brakes and a clucking noise
Old Aug 26, 2010 | 06:40 AM
stone150's Avatar
Default 2 question: New Brakes and a clucking noise
these are separate questions.
I need new brakes and I was thinking about going with DBA 4000 slotted rotors and stock gm pads, any thoughts? I currently have power slots or ssbc rotors and ebc green pads and I am not happy at all with the performance. It is very poor.
In full lock after moving a short distance I get a loud clunking noise. I also get it when making a fast left hand corner (like going under the freeway onto the frontage road) It also happens sometimes (not regulalry) while pulling out of the driveway (which has a bump at the bottom). someone suggested it may be the cv axle. recently replaced the tie rod ends, so i don't think it is that, unless i got a bad one.
Old Aug 26, 2010 | 07:08 AM
Coban's Avatar
I recommend going with tahoe rear calipers and rotors and going with 05+ front calipers and rotors. All OEM.
Old Aug 27, 2010 | 06:33 AM
stone150's Avatar
do they just bolt up? what's the difference on the rear?
Old Aug 27, 2010 | 06:44 AM
mhotrodscooter's Avatar
Check the swaybar bushings & end links. Look @ shock mount rubbers too!
Old Aug 27, 2010 | 06:49 AM
dhpro's Avatar
The clunking cud be the rear end...mine did it when the ring/pinion went. It was really noticeable when I reversed and turned...clunk, clunk was the locker not releasing. Also happens without the additive in the fluid. U can feel it thru the drivetrain. I also had CV joint wear out and it had some similar noises and bumps, but it was more a grinding, rubbing sloppy feeling. Check both...CV's are pretty simple and cheap to fix (maybe $125 for both with core exchange).
Old Aug 27, 2010 | 08:54 AM
Coban's Avatar
Yep, bolt up. Tahoe rear rotors are thicker, and use dual piston calipers. You must get the caliper brackets as well to make it bolt and go.
Old Aug 27, 2010 | 09:41 AM
Robert91RS's Avatar
Sounds dumb, but check your caliper bracket bolts. I see them come loose on a pretty regular basis after a brake job has been done. Sometimes they fall out and go missing all together. I'm no sure if they aren't getting torqued down enough or if the thread locker has just worn off.
Old Aug 30, 2010 | 06:16 PM
stone150's Avatar
Coban, whats the deal with the 05 fronts?
I checked the sway bars and shocks (new) and they were fine, i replaced the end links as soon as i bought the truck with the poly ones and they still look good. If i grab the drivers cv axle, it moves some and makes noise. if i do the same to the other side it moves less and while it makes a noise it is much quieter.
I know the rear pinion going into to transmission is the old design that clunks, but i herd the new design only fixes it for a short while.
Old Aug 30, 2010 | 06:45 PM
Jack the side up with the most noise (with it in 4wd) & try to turn the tire. Sounds like it a broke cv joint
Old Aug 30, 2010 | 08:34 PM
Coban's Avatar
Dual piston PBR calipers, and 1" larger rotors for the 05+ front brakes.
RustyD
May 23, 2016 07:04 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
