160* stat???
Ya I noticed a few people on here have 160*, and I was just wondering, wat exactly does this do? I know it obviously drops the temp but does it have any hp gain or what? Also what is a vette servo? I also see a few people have these but never figured out what it is, thx fellas
lowering our operating temperature allows us to play with timing more. Cooler temps....more timing. Of course there is a balance here...the motor won't run to well at all if you keep the temps at 130*.
Vette servo and shift kits are trans modifications for firmer and more reliable shifts. The vette servo will help the trans handle the harder shifts as well. That's a lamen explanation..the real trans tech guys will chime in with the TMI I am sure though if you want more info.
I just happened to find a Corvette servo install write up (not sure which vehicle, but the operation is the same) that may be helpful.
http://s-series.org/Sections-index-r...-artid-29.html
As for the cooler stat, I run a 160* stat for a few reasons...mainly to keep my eng temps cooler to allow me to run more timing and more compression when I have my LQ9 in there. My opinion is if you install a cooler stat, you really should have the PCM tuned accordingly, to both optimize the effects of running cooler and to compensate for the cooler temps that may "confuse" the PCM. The combination of the 160* stat and e-fans allow me to keep it running precisely where I want it, around 175* (fans come on at 180* and off at 173*).
I agree with both dew and bud, but just to add to that... if you install a 160* T-stat and do not tune for it there will be no positive effects on your engine. And there will also be a nasty drop in MPG. On the upside it is one of the easiest and greatly beneficial mod you can do for the price, especially on an LQ9.
My LQ9 160* therm does not keep the temp at 160*. When the truck was stock the 185* therm let kept the truck at 205* plus up to 230*. After the therm and a tune setting the fans at 185* on low and 198* on high the truck now only hits 200* and comes back down to 185* fast. I have elect fans.
Originally Posted by RoninsDenali
So does the 160* stat have any issues in cold weather environments? (assuming everything is properly tuned)
Just a little update...13* this morning and I still had great heat. I let the truck warm up for about 5 or 10 minutes while I ate a bowl of cereal and looked for my warm hat, and when I came out it was almost in operating temperature. Turned on the heater fan and it was already blowing warm...half way to work, it was blowing HOT (had to take off the warm hat
So far, this 160* stat is reacting just like every other one I've used in the past during the winter
) So far, this 160* stat is reacting just like every other one I've used in the past during the winter
Ram4Pick
Jul 21, 2003 12:08 PM
Ram4Pick
May 1, 2003 05:13 PM
Ram4Pick
Apr 28, 2003 01:09 PM
