160* stat installed, setting on the electric fans?
Old Apr 26, 2003 | 08:52 PM
Default 160* stat installed, setting on the electric fans?
I just installed an SLP 160* stat on my truck and was wondering what temp I sould set my electric fans to come at? I was thinking about 180*! The needle on the temp gauge is about three marks lower than with the stock 195* stat., it's a touch past the thick middle mark on the gauge with out a temp indicator. On a side note! I don't think the 160* mark on the temp gauge is right. On my 95 truck, the lower mark was 100*, this truck it's 160*. When I start my truck, the needle starts to move only after about 30 seconds or so, I don't really think the coolant temp is 160* already. I also ran a 160* stat in my 95 truck and the needle is in the same spot on this truck as it was in the 95 truck. I still think the lower mark is closer to 100* not 160*, but I could be wrong.
Jim
Old Apr 27, 2003 | 02:11 PM
Hit Man X's Avatar
Default Re: 160* stat installed, setting on the electric fans?
I'd go 180-190* for the fan turn on.
Is your truck faster from this lower thermostat? Also, think you MPGs will be effected?
Old Apr 27, 2003 | 03:49 PM
My fans come on at 180 degrees in traffic with AC on my temps never run over 195 degrees.
Old Apr 28, 2003 | 12:21 AM
I set the fans to come on at about 175-180*, I'll play with it some if they come on to much. Can I tell if the trucks faster, only the track or my 0-60 will show that although the SOTP meter says yes. Driving home in the rain from work tonight, it got a littel slippery a few times. I would take off from a light with very little gas to keep from spinning the tires, when I started to give it more gas when I thought it was safe to do so, the tires broke loose and kept spining when the trans shifted into second. So just from that, I think the engines making more power. I almost lost it going around one corner, turned right on a green going about 15-20 mph, the trans was in 2nd gear, I stepped on the gas lightly and the tires broke loose the the tail started to swing. I caught it alright though, but had to give it less gas from that point. Driving in the rain is going to be more fun the quicker I get my truck.
Jim
Old Apr 28, 2003 | 01:28 AM
Ryan23silverado's Avatar
No, you are correct Y2K Silverado. The lower mark on the temp. gauge should be 100* This is what AutoTap reads it to be at when the needle is in that position. My friend's 2002 S-10 is labeled with that bottom line as 100* I wonder why GM decided to make it 160* on ours b/c it is off big time. On that note, the fuel gauge also sucks! It is not calibrated well at all. It takes a while to go from full to half-full, but no time at all to go from the half-full position to empty. Who knows...?
Old Apr 28, 2003 | 01:09 PM
Hit Man X's Avatar
Glad that 160* works well now. If/when you do some 0-60 runs, post them up as I am intrigued.
5.3Okasai
Mar 9, 2022 01:07 PM
Bluchevypick
Aug 18, 2015 09:11 AM
Ketis
Jul 23, 2015 12:37 PM
01sierraon22s
Jul 8, 2015 11:26 AM
