05 radiator/fan swap in a 03?
Old Aug 15, 2006 | 09:53 AM
Default 05 radiator/fan swap in a 03?
does anyone know if i could swap in a 34" radiator and electric fan set-up from an 05 into a 03 with the smaller radiator and clutch fan? just want to know if everything slides into place or will there be fabrication needed. i know the hose are different to so they would be replaced to.
Old Aug 15, 2006 | 10:07 AM
im pretty sure everything should fit right up but not positive
Old Aug 15, 2006 | 10:47 AM
yea, just need to know for sure because i don't want to cut the truck up
Old Aug 15, 2006 | 10:55 AM
thunder550's Avatar
High on diesel fumes
Yes it will all fit. You can even reuse your original hoses. The only modification you need to make is to the rubber material around the radiator - you will have to cut it a littl ebit to line up with the edges of the larger radiator.
Old Aug 15, 2006 | 11:49 AM
i would need to cut the rubber to line up with what
and could the 03 pcm run the electric fans? is there a program that is there but not turned on.
Old Aug 15, 2006 | 11:56 AM
thunder550's Avatar
There is a rubber/foam material behind the headlights and such that keeps air from flowing around the radiator. Since the 34" radiator is wider than the 27" radiator, you have to cut it or the rubber will overlap the sides of the larger radiator and block airflow. It's real easy to do, not a big deal at all.
The fan option can be enabled in your PCM - just need to have someone change it in the tune.
Old Aug 15, 2006 | 12:12 PM
thats great, it's everything i needed to know, thanks
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
XL7
May 5, 2022 01:48 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
superchomper2003
Aug 26, 2015 09:39 AM
iregret
Jul 27, 2015 10:32 PM
