03 Yukon steering hard at idle
Old Jul 27, 2013 | 11:46 AM
PSI GUY's Avatar
Default 03 Yukon steering hard at idle
Had the truck for three years now, only in the last week the steering is very hard to turn at idle when stopped. I have had 305 tires on it for the three years I've had it but it has always been easy to turn. There is no pump whine or other symptoms to note, once rolling or moving the steering effort returns to normal. Should I flush the fluid out or is there a relief valve something that can be serviced? My buddy has an 04 SS and his has done the same thing since he has owned it, I told him it steered like crap now karma has bit me.
Any ideas?
Old Jul 27, 2013 | 03:23 PM
Suburbazine's Avatar
Most likely the EPC solenoid or the steering angle sensor on the steering shaft under the dash has failed. The pump has a small electronically controlled valve on the bottom that modulates idle boost pressure. This is controlled by the ABS module which gets signal from the angle sensor.
The simple test is to reach behind the pump and unplug the red electrical connector, then go for a test drive. With it unplugged you should have too much steering assist at all speeds.
ARC
57
Feb 21, 2022 10:54 AM
Ketis
Jul 23, 2015 12:37 PM
1320Chicken
Jul 14, 2015 10:58 PM
lxcoupe
Jul 8, 2015 05:49 AM
cwylie
Jul 7, 2015 11:42 AM
