WTS: Flex-A-Lite EFans
Are these wired to the PCM like the nelson harness or how do you control on and off? Also, do they bolt right in to the where the factory fan and shroud is located on an 03 silverado ss with the 34" radiator? Thanks.
These are sized for the stock 28" radiator!! They dont "Come" with a wiring harness for the PCM, but are capable of using it. I had them setup on my truck with nelsons harness which is why the VSC it comes with is still new. The VSC is a Variable Speed Controller. It uses a temp probe that you place in your radiator and it turns the fans on. Also can switch to high output mode on fans as well.
Only thing is, if you have a 34" radiator this might be too small for you
Also, do you have the brackets to go with them.
