TN - Nitto Drag Radials and Wheels
Old Jan 26, 2010 | 04:06 PM
2 tone 02's Avatar
Default TN - Nitto Drag Radials and Wheels
I've got a set of pretty much brand new 275/60r15 nitto drag radials on 15x8 craggar soft 8s. They have approximately 100 miles and ZERO burnouts or launches!! $300 picked up in memphis.
Will take close ups of the tread tonight
Old Jan 27, 2010 | 12:18 AM
ss04flores's Avatar
15?! i thought they didnt clear the caliper?
Old Jan 27, 2010 | 08:51 AM
quicksilverado's Avatar
They do after you grind the calipers.
Old Jan 27, 2010 | 12:00 PM
03 True Fire's Avatar
yup, i started a thread about that awhile back, drums fit 15s like nothing, caliper you have to grind
Old Jan 27, 2010 | 02:21 PM
2 tone 02's Avatar
Yes, they clear drum rears fine, but you have to grind the caliper and bracket to fit 15s.
If anyone with a disc rear wants these, I will swap rear calipers and brackets with them, so it will save you some time/effort to grind yours!
Old Jan 27, 2010 | 07:31 PM
sprayed99's Avatar
SPecs on the wheels please? BS? do they hit with your 6inch drop in the rear?
Old Jan 27, 2010 | 08:50 PM
2 tone 02's Avatar
15x8 cragar soft 8s, 4.75" BS, They only rubbed slightly when I had a 1/4 spacer on the passenger side, but after grinding the caliper alittle more to run without a spacer and rolling the fender, I had no issues. Also I am at a 7" rear drop, not 6.
Old Jan 27, 2010 | 09:22 PM
2 tone 02's Avatar
Old Jan 28, 2010 | 03:01 AM
BadAssChevy327's Avatar
mannnnn these are sweeet. ill pm you
Old Jan 31, 2010 | 01:05 PM
2 tone 02's Avatar
Bump!
