Throttle Body Screws Needed
Old Apr 5, 2006 | 07:57 AM
SSlow 4.8's Avatar
Default Throttle Body Screws Needed
Well, I cant seem to find the part number on these. If no one on here has them im going to go to the gm parts store and see if they have them. But its just those three screws attaching the throttle body. If someone has the really long ones for the tb spacer than great, i'll take those, but if not stockers will be fine.
Old Apr 5, 2006 | 08:25 AM
BLACKND's Avatar
Are you talking about the 3 studs that the throttle body bolt on to? I have one, but they are like 12 bucks each at the dealer. No ****, you'd be better off just buying the longer spacer bolts.
Old Apr 5, 2006 | 08:31 AM
SSlow 4.8's Avatar
well.. they're screws. By stud, you dont mean what the screw is SCREWING into do you? You mean the screw itself... sorry that just confused me.
What do you have one of? The stock bolts or the longer spacer bolts?
Old Apr 5, 2006 | 09:17 AM
BLACKND's Avatar
Well, on my 04 GMC, there were actually 3 studs that screwed into the intake manifold and then the throttle body bolted onto these with a nut. Basically they were threaded on one end and then reverse threaded on the other.
Old Apr 5, 2006 | 09:53 AM
Fogle07's Avatar
yea joe from the factory your tb is held on my 3 nuts. theres studs into the intake and your tb slides over it and is attached with the nuts. when you get a spacer you take the studs out and just use the longer bolts that come with the spacer.
Old Apr 5, 2006 | 10:09 AM
SSlow 4.8's Avatar
something doesnt make sense in that sentence... i worry about you steven.
oh alright.. i forgot its been so long... your right... well L33... how many studs do you have? all 3 would be nice?
Old Apr 5, 2006 | 10:18 AM
Fogle07's Avatar
yea like dr. evil making sure he had his 3 nuts. ill see if i can find the part number for them
Old Apr 5, 2006 | 10:36 AM
SSlow 4.8's Avatar
alright thanks... i had a feeling they were going to be stupid expensive.. lol $12 a pop and i say screw it.. i'll take a risk at napa, lol. Let me know what you find steven, thanks.
Old Apr 5, 2006 | 10:56 AM
Fogle07's Avatar
my book didnt have the intake in it. i believe the spacer i got from you is at the house but if you can wait a couple days ill get you some.
Old Apr 5, 2006 | 12:20 PM
krambo's Avatar
6mm x 40mm bolts will work fine. Depending on what TB you have, you will have to go longer or shorter or use a washer. Get them from Home Depot in the pull-out drawers,...stainless are like $0.80 a piece.
