Rossler Terminator 5 truck trans!!** Converter Flex Plate & Shifter
Perfect trans for one of our trucks boys! Will make a package deal for forum member.
This stuff is all new never ran.
I have a never used Rossler Turbo 400 TH400 Terminator 5 with a few options. $4500.00
Standard Equipment:
-Ross-Lock pro tree trans brake reverse shift
-Rear case thrust bearing
-Glass bead, trim ears, prep case for racing
-HP overhaul new bushings, seals, gaskets clutches
-High flow HP filter
-Patented snap ring stabilizer
-Special design M300 billet input shaft
-Billet M300 intermediate shaft
-CNC modified forward drum with over sized spline for extra durability with Rossler exclusive shaft retainer system to prevent shaft movement
-Billet forward clutch hub
-H.D. 36 element oversized pro-mod sprag, twice the surface area of a regular 34 element sprag, aircraft grade quality 7075-t6, billet aluminum high gear drum, eliminates 4.5lbs of rotating weight from transmission. also prevents drum explosion!! for durability and safety, with billet steel sleeve to prevent premature sealing ring wear in drum bore.
-H.D. clutch packs
-Made in house, Rossler billet 5 pinion carrier for 248 gear set with single pinion thrust bearings
Options/Upgrades:
Clean Neutral shift pattern
Ultra Bell for LS LSX engines
Speedometer Sensor
Trans Coolant Line Fittings
RTI Cast Aluminum pan
Lokar Flexible dip stick.
Precision converter spec'd by Dusty Bradford for turbo LS motor. $800
TCI LS LSX flex plate part# 399753 with ARP flexplate bolts part# 244-2901 $200
Precision Performance Products clean neutral air shifter with polished mount brackets, shifter cable and coiled cord. I paid $600 will take $450, everything new in box.
Will make package deal for whole combination.
Local pick up only.
Jason 734-658-2124
Standard Equipment:
-H.D. clutch packs
Options/Upgrades:
Speedometer Sensor
Local pick up only.
Jason 734-658-2124
arthursc2
Feb 13, 2017 02:45 PM
TigerFan187
Oct 13, 2006 06:16 PM
TurboBerserker
20
Aug 10, 2004 10:42 PM
