No2 system GM one piece MAF sensor
Dont really want to sell this kit but I need some quick cash,Nitrous express kit number is 20110-10 and this is a mass air flow system,the solenoids are mounted on a plate after the Maf sensor,it is a wet kit with both fuel and NO2 sprayed at the time,I am selling all of the kit,lines,bottle,REMOTE OPENER,jets, all of it EXPECT the switches in the cab,which a run to autozone can get new switches,I will pull the switch out for the remote opener as that is a switch you might be hard to find.
This was a wide open switch,was a very easy system to wire up,two boxes under the hood and I had a fuse put in line as well.
Pics up soon but here is a run dow,
1.White 10pd bottle.
2.MAF system with the solenoids all ready hooked up.
3.wires and relays for the kit-you will need to get some wire to make it work for your application
4.Remote opener
5.PSI gauge still on the bottle
6.Bottle Blanket
7.Extra Solenoid
8.All the jets I got
9.Instructions and the standard bottle opener
10. fuel and NO2 lines from the fuel rail to the fuel solenoid and from the bottle in the bed to the NO2 solenoid
11. Bottle mount.
$1,000 takes it all,pay pal or cash or money order.
419-559-1551.
4.Remote opener
6.Bottle Blanket
7.Extra Solenoid
11. Bottle mount.
419-559-1551.
