MSD - 8982 Start/Retard Controler --good with Nitrous--
120 + Shipping
comes with msd controler and extra pills
i have pictures that i will post when i get home or i can email them just pm me.
Summit Racings descriptions ....
Brand: MSD Ignition
Product Line: MSD Start/Retard Controls
Part Type: Timing Controllers, Electronic
Part Number: MSD-8982
Circuitry: Analog
Controls Ignition Advance: No
Controls Ignition Retard: Yes
Use with Locked Distributor: Yes
Controller Activation: Programmable
Adjustable: Yes
Adjustment Style: Pills
Ignition Box Required: Yes
Compatible with Multiple Coil Ignitions: No
Quantity: Sold individually.
Easy timing and start control.
These start/retard timing controls are the direct results of MSD being at the races and listening to what racers want. With the large number of engines running locked-out timing, racers wanted a simple way to retard the timing during cranking, plus have a single stage of retard available for high rpm or nitrous.
The start/retard controls let you choose either 10 or 25 degrees of retard during cranking only. The timing will retard only while cranking, and returns to the set mechanical timing once the engine starts and you release the key, or once the engine reaches 1,300 rpm. Along with the start retard, these units also have a single stage of retard. This retard can be activated in times of nitrous to prevent detonation, or at high rpm to achieve a little more top end. The amount of retard is adjustable with plug-in modules, and is activated by a single wire that can be connected directly to a nitrous solenoid, or a microswitch on the shifter. The start/retard controls are easy to install and program, and are supplied with 2, 3, and 4 degree modules. They must be used with an MSD 6, SCI, 7, 8, or 10 ignition control.
Brand: MSD Ignition
Circuitry: Analog
Adjustable: Yes
