modified return style fuel rails
Old Sep 27, 2012 | 07:40 PM
AndysC3's Avatar
Default modified return style fuel rails
I have the stock return rails that have been modified to work with the TBSS/NNBS intake. The crossover has been cut and -6an fittings have been welded on. This would be a great way to run the tbss intake on your 99-02 trucks. asking 75 shipped
this is the only picture that I have of them.
the crossover is not included. you will need 2 -6an fittings and about 10" of -6an line
the zip ties are holding the rail down because I messed up the mounting post. the rails are in perfect condition
Old Sep 28, 2012 | 08:49 PM
foreverfalcon40's Avatar
How would this work on an swapped OBS?
Old Sep 28, 2012 | 09:23 PM
AndysC3's Avatar
it bolts up to the gen III/IV truck intakes.
Old Sep 29, 2012 | 05:54 AM
iregret's Avatar
Charlie Murphy!
What did you do for a throttle body?
Old Sep 29, 2012 | 07:39 AM
AndysC3's Avatar
its a ls2 90mm tb
Old Sep 29, 2012 | 07:45 AM
iregret's Avatar
Charlie Murphy!
So I've got a 2005 6.0L that I'm planning on swapping in. I believe it's the same intake manifold as the tbss. Are you saying I can get a LS2 90mm tb and it would bolt up to the newer style intake? Is it cable driven? Did you swap to dbw? I'm trying to figure out what all I'd have to get to make the setup work.
Thanks man.
Old Sep 29, 2012 | 08:54 AM
AndysC3's Avatar
The 05 uses a 3 bolt 78mm tb. you would need a 07.5+ or a TBSS intake manifold to run the 90mm tb. My truck came with DBW. I just needed a conversion harness to make it work. This is for a return style fuel system.
Old Oct 1, 2012 | 05:59 AM
AndysC3's Avatar
bump. open to offers
Old Oct 4, 2012 | 06:26 PM
AndysC3's Avatar
Bump.
Old Oct 4, 2012 | 07:22 PM
darnie's Avatar
2 bad mines returnless i been thinking of doing the swap but.... i think im doing ok with the new one i got Bump for a good dude
