G-tech Performance Meter
Old Oct 1, 2006 | 06:15 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Default G-tech Performance Meter
Used a few times. Works great. Fairly accurate and works good for tuning and trying things. $60 shipped, includes instruction manual but you won't need it.
Old Oct 1, 2006 | 06:28 PM
FarmerBeau's Avatar
Sexy Party Mod
Price?
Old Oct 1, 2006 | 08:29 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
It's in the first post $60 shipped!
Old Oct 2, 2006 | 07:53 PM
Mangled03gmc's Avatar
Baltimore Whore
Hey just for *****, how acurate is it??
Old Oct 2, 2006 | 08:20 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I was within' a tenth and a half or so at the track. Also, I tested it on the street (and posted about it) and it said 14.60. I went to the track a few days later and went 14.40, 14.2, and 14.56. It's pretty close, I don't know how....but it works pretty good! lol I used to make about 10 runs, average them out, and then do so for each mod. It kinda gave me a close gain from each little thing.
Old Oct 3, 2006 | 12:42 PM
'89ChevyMadneSS's Avatar
what all features does this model have? VERY interested!
a link to this specific model will do if it would save you some trouble
Old Oct 3, 2006 | 06:59 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
Measures seven important performance characteristics like horsepower, 0-60 mph, 60-0 braking, 1/4 mile ET, 1/4 mile speed, instantaneous G, and coninuous G-Force. That way, you can have the before and after modification numbers to support your adjustments. And all you have to do is plug the unit into your cigarette lighter and mount it to your windshield. You'll have the hard numbers you need right in front of you on a 4 digit LED display.
G-TECH/Pro takes advantage of many different measurements that can be gathered from acceleration over time. For Horsepower measurement the user has to input the weight of the vehicle. We utilize what we call "Intuitive User Interface". To input weight all you have to do is simply tilt G-TECH/Pro up and the numbers will increase and if you tilt it down the numbers will decrease. Further you tilt it faster the numbers change.
In Horsepower mode G-TECH/Pro will display currently delivered horsepower during acceleration and then when you slow down it will display maximum delivered horsepower. All the measurements are performed automatically. All you have to do is push the button indicating to G-TECH/Pro that you are ready and then G-TECH/Pro will zero-out and display -GO-. Then simply start accelerating. G-TECH/Pro will know your speed and distance at any given moment and stop the measurement at 60 mph or 1/4 mile point.
While measuring Lateral or Longitudinal G's user has the choice of Instantaneous or Continuous mode. Instantaneous G's are great for analyzing when tires lost traction during braking and cornering or measuring any other kind of G-load. Continuous G's are designed for standard Skidpad handling measurements of Lateral G's.
When measuring Braking distance in feet user doesn't have to start braking exactly at 60 mph. G-TECH/Pro knows the speed always and it will only measure distance from 60-0 mph even if you started braking at 65 mph for example.
The heart of the G-TECH/Pro is a precision silicon accelerometer. An accelerometer is a sensor that measures acceleration, also known as G-Force. G-Force is what's keeping you in your seat as you are reading these words and if it wasn't for the seat you would be accelerating to the ground at 1G (32 feet per second per second).
G-TECH/Pro measures your speed and distance traveled by integrating acceleration over time. Basically, if you know how fast you are accelerating for a certain time period you'll know how much your speed has changed after that time period. So, if you start of from zero speed then you'll know what your speed is after every time period. These time periods are very small (2.5 milliseconds) and that's how G-TECH/Pro maintains its accuracy.
Distance is measured in the same fashion, if you know how fast you are going for a certain time period you will know what is the distance traveled during that time period.
G-TECH/Pro also measures delivered Horsepower, sometimes called Rear Wheel Horsepower. This horsepower includes the loss of power through the drivetrain which is usually 10-15%. The formula for Horsepower is speed times acceleration times the weight of the vehicle.
The best way to look at accuracy is in two different ways. Resolution is the smallest segment of a given measurement that G-TECH/Pro can sense. Real Life accuracy is the worst case scenario to be expected in your measurements. The difference between Resolution and Real Life accuracy is the result of noise, temperature dependency, vibration and other elements that influence the accelerometer and other internal electronic circuitry.
Our accelerometer is one of the best in the world. It starts out as a 1/8 inch silicone cube. Then it's laser sliced in to a sandwich with the critical mass in the middle. It sits in the specially designed silicone gel with dampening characteristics tailored for automotive dynamics. On top of all this there is a special accelerometer enclosure with grounded metal layer for EMI shielding. We at TESLA Electronics believe that the best way to insure accuracy is to get a good, clean signal from the outside world and that's why the accelerometer in the G-TECH/Pro costs more than all other parts put together.
What's the maximum G range of the G-TECH/Pro?
In order to acheive such high accuracy Maximum G range of G-TECH/Pro is ~1.3 G's. This is fine for all the cars who's 1/4 mile E.T.'s are above 7 seconds. If you have a car that's below 7 seconds you may experience inaccurate measurements due to clipping. Clipping is when the amount of G-Forces exceeds the limits of G-TECH/Pro. This can't hurt G-TECH/Pro but it can upset the measurements. Clipping will manifest itself by longer times than expected.
Can G-TECH/Pro be used on motorcycles?
This question is somewhat related to the one above. Some motorcycles deliver G's that exced 1.3 G range. G-TECH/Pro wasn't designed for use with motorcycles. However, some customers have used it with motorcycles with success. It's very hard to say what G's (and for how long) can your motorcycle deliver even if you know it's E.T.'s. In this case our Risk Free Money Back Guarantee can come in handy.
Why is my G-TECH/Pro consistently 2-3 mph above the track?
G-TECH/Pro is a very accurate machine, and the trap speed result that you get from the G-TECH/Pro is actually more accurate than the racetrack. Reason is that the racetrack averages your speed over a 60 feet stretch between two beams and G-TECH/Pro measures your speed at the exact 1/4 mile point.
Old Oct 3, 2006 | 08:43 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
That rascal was sold!!! Thanks
Old Oct 4, 2006 | 12:46 PM
damnitt!!!!!!!!!! to slow
mikeyjm1
17
Oct 29, 2015 11:04 PM
gaps
Oct 15, 2015 02:53 PM
gavin2005
Sep 13, 2015 09:04 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
montecarloss
Sep 2, 2015 04:44 PM
