Fs: RPM Lvl 6 4l60E Transmission "BRAND NEW"
Sold**
For sale is a brand new, never used RPM Level VI 4wd 4L60E/4L65E/4L70E automatic transmission.
I bought this from another member on here "Casper". I bought it under the assumption it was a 2wd transmission... It's not, It's a 4wd.
It's fits 99-08 gm trucks, SUVs.
SOLD** pending cleared check
Located in Temple, Tx
Call or text 254-913-8228 with any questions..
Original ad: https://www.performancetrucks.net/fo...nd-new-532090/
All of our LEVEL VI 4L60E/4L65E/4L70E automatic transmissions include:
*Media blast transmission case
*RPM Level V 3-4 clutch pack
*RPM reinforced sunshell with collar and bearing
*Heavy Duty double caged 29 element sprag
*4L65E low roller clutch
*Billet 4th gear servo
*Transgo HD-2 shift kit
*Corvette Servo
*Wide 2-4 band
*Updated aluminum accumulator piston
*Bushing kit
*New shift solenoids
*New GM valve body spacer plate
*Seal & gasket kit
*GM Filter
*RPM Spec clutch and band clearances
*RPM sleeved input drum
*Billet over-run piston
*GM 5 pinion planetary gearsets - front and rear
*NEW Extra WIDE Heavy Duty double caged 29 element sprag
*300m Billet output shaft
*4L65/70E low roller clutch
*Each transmission is dyno-tested before shipping
*Corvette Servo
*Wide 2-4 band
*Bushing kit
*Seal & gasket kit
*GM Filter
Because I don't want to have some "Trans shop" opening this level 6 up to swap in a non-billet output shaft. Or just tearing into a perfect transmission. There's not a reputable transmission shop around me. I bit the bullet and just went ahead and ordered a lvl 6 2wd directly from RPM for 3,069.
