E-Fan harness dual pin
Old 07-06-2012, 12:05 PM
TXSZ66AVLANCHE's Avatar
Default E-Fan harness dual pin- pictures added
Two fan harnesses for sale, dual pin. Made for 2005 truck fans. $80 each plus the ride.
Old 07-16-2012, 07:04 PM
Who doesn't like pictures? Harness is approximately 63" long and can be mounted under the driver side fender brace area.
Old 07-16-2012, 10:36 PM
OrangeChevyII's Avatar
Where are you located?
Old 07-17-2012, 02:10 AM
Denton, Texas
Old 07-17-2012, 06:26 PM
Bruce Pittman's Avatar
Default Harness
this style setup eliminates the need for the VSC?
Old 07-17-2012, 09:04 PM
What is vsc?
Old 07-17-2012, 10:18 PM
cammed00's Avatar
I think he's talking about Variable Speed Control for the fans.
Old 07-17-2012, 10:27 PM
Fastcount03's Avatar
I will take one! Please pm me your info. Thanks.
Old 07-18-2012, 12:03 AM
yes, read on here and else where some trucks use this:
when using Flex-a-lite e-fans, was wondering if i need to still pick one up if using your harness. i have the front end apart doing a slow blown waterpump & cameshaft upgrade, since everything is off @ this point, wanted to upgrade to LS1 style or 05-up factory e-fans.
Old 07-18-2012, 05:46 AM
This setup does not need variable speed control, ground one of the pcm wires and both fans run low speed, ground both pcm wires and both fans run high speed.
Obviously a tune is the best way to run the fans so they are automatic...but you could just use a toggle switch.
Quick Reply: E-Fan harness dual pin
