Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!
Old Dec 27, 2008 | 02:49 PM
tbyrne's Avatar
Default Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!
I've been doing a little cleaning so I have a bunch of truck stuff for sale -
Factory grill - came off of a 2002 3/4 ton Suburban. I'm pretty sure the 1/2 ton Suburbans use the same grill. It is also the same for the 1500 series Silverado (1999-'02) - $100.00
Edge A2 Monitor #83300 - $625.00
2003-2007 Ford Powerstroke Diesel 6.0L
1994-2003 Ford Powerstroke Diesel 7.3L
1988-2004 Dodge Cummins Diesel 5.9L
2001-Early 2004 GM Duramax Diesel 6.6L
Late 2004-2006 GM Duramax Diesel 6.6L LLY
Late 2004-2007 Dodge Cummins Diesel 5.9L 600
2006-2007 GM Duramax Diesel 6.6L LBZ
1997-2007 Ford F-Series
Edge Back-up Camera - $145.00
(the camera and A2 package are new. I had a different A2 that had to be replaced under warranty. I ended up going with different tuning after I pulled the DPF off so I don't need this one anymore)
LS1 ScanMaster - $140.00
I'll be listing some more truck stuff shortly. Also came across some factory f-body parts.
Shipping cost will depend on where the parts are going to.
Thanks!
Attached Thumbnails Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-grillchevy.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-edgenew1.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-edgecamera.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-scanmaster.jpg
Old Dec 27, 2008 | 02:57 PM
tbyrne's Avatar
4" lift blocks - $25.00
(I might have U-bolts for these. Just need to come across them. $60.00 with the bolts if I have them).
Head rests from a 2007 GMC Sierra - $100.00
Leaf springs from a 2007 Sierra HD. Were on the truck for a few thousand miles - $150.00
Another set of 4" lift blocks - $25.00
Tuff Country SX8000 Shocks - $120.00
(Front shocks - 61232
Rear shocks - 61301
Designed to be used with a 6" lift)
Attached Thumbnails Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-blocks2.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-headrests07.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-leafs.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-blocks.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-tcshocks.jpg
Old Dec 27, 2008 | 03:09 PM
tbyrne's Avatar
2 Bilstein Shocks - F4-BE5-6249-H5 - 12" with 255/70 Med/HD valving 11.94" Travel 17.91" Collapsed 29.7" Extended - $110.00
Carriage Works Polished Grill (2007.5+ GMC - New) - $110.00
(One nut and bolt ran away but everything else is there)
Also have a set of factory 8.1 heads along with manifolds for those and possibly a set from a 5.3 if anyone is interested. I'll post those when they are dug out.
Attached Thumbnails Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-bilstein.jpg   Back-up Camera, DashHawk, Factory Grill, Leaf Springs, Edge A2 Plus More inside!-grill2.jpg
Old Dec 27, 2008 | 10:35 PM
let me know about the 5.3 heads. pm if you want. will have to be shipped.
Old Dec 28, 2008 | 10:27 AM
OnyxSilveradoSS's Avatar
back to the land of the living
Old Dec 28, 2008 | 02:09 PM
tbyrne's Avatar
Have heads for an 8.1. Just exhaust manifolds for a 5.3.
Yup! Actually, been around for a little bit but not in this area much
Old Dec 28, 2008 | 09:24 PM
tbyrne's Avatar
Edge Juice with Attitude for an LMM diesel. Used for about 6 months. I have a new EGR probe that I can include with everything as shown.
KEY FEATURES:
• 6 on-the-fly Adjustable Power Levels
• Touch-of-a-Button Control
• Additional 90 HP and 225 ft lb Torque*
• Increases Fuel Economy**
• Includes Turbo Timer
• Displays DPF (Diesel Particulate Filter) Regeneration Status
The Edge Juice with Attitude is a highly sophisticated package capable of dramatically improving your Duramax's driveability, towing, mileage and, most importantly, POWER.
The Juice module is a completely weatherproof module that installs under the hood. Using factory-style connections, in just 30 minutes you can add up to six levels of adjustable power ranging from 30 to 90 horsepower and increase torque up to 225 ft. lbs.
The Juice greatly improves responsiveness and driveability, while at the same time increasing fuel economy. The Turbo Timer is the latest in a long list of Edge safeguards. This feature prolongs turbo life by allowing the truck to run after shut-off for a predetermined time or until a specific EGT is reached.
When used in conjunction with the Attitude monitor, you can control the six power levels on the fly from inside the cab of your truck. The Attitude displays all the information a set of gauges would and automatically monitors exhaust gas temperature (EGT) and de-fuels the engine to prevent excessive EGTs. Imagine one simple 30-40 minute installation and you get incredible power gains, an increase in mileage, and the equivalent of a complete set of gauges!
The following power gains are representative of an actual test vehicle. These gains were measured on a SuperFlow Dyno at an altitude of 4400 ft above sea level, and represent power delivered to the rear wheels of the test truck. The only modification made to the test truck was the addition of the Edge Juice module. Power gains may vary based on vehicle and geographical location.
Level 0: Stock
Level 1: 30 Horsepower - 60 Foot Pounds of Torque
Level 2: 40 Horsepower - 80 Foot Pounds of Torque
Level 3: 50 Horsepower - 95 Foot Pounds of Torque
Level 4: 60 Horsepower - 115 Foot Pounds of Torque
Level 5: 80 Horsepower - 135 Foot Pounds of Torque
Level 6*: 90 Horsepower - 225 Foot Pounds of Torque
*Hot Unlock Code plus additional fee required for level 6. For pricing information and to get the unlock code you must complete a waiver located under hot unlock form.
Your Attitude monitor allows you to monitor the performance of your engine's vital components and output values. The following parameters can be displayed on the main Attitude screen (maximum 4 at one time):
• EGT (exhaust gas temperature)
• DPF Regeneration Status
• Barometric PSI
• True Speed (corrected for tire size)
• Gear (torque converter lock)
• Intake Air Temp
• Load %
• Transmission Temp
• Throttle %
• Turbo Boost PSI
• RPM
• Back down (Percent back down due to high EGT)
• ECM Volts
• Engine Coolant Temp
• Fuel Temp (measure in the fuel rail)
• Module Temp
That Attitude can sound an alert when certain engine parameter levels are met. The following alerts are available:
• EGT
• Boost
Keep track of your performance by recording maximum/minimum for a variety of parameters including:
• Max RPM
• Backdown %
Usually sells for about $850.00
Old Dec 29, 2008 | 10:10 PM
tbyrne's Avatar
The Air Lift is no longer available.
Old Jan 1, 2009 | 03:40 PM
tbyrne's Avatar
Dash Hawk is sold.
Old Jan 4, 2009 | 08:57 PM
tbyrne's Avatar
Listing updated
