8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.
Old Oct 9, 2017 | 08:09 PM
z1kman's Avatar
Default 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.
Sold my truck and have everything to build a decent 10 bolt and a few T56 swap parts
Yukon axles $275
Yukon Dura Grip locker $390 - SOLD!
Yukon 456 gears $175 - SOLD!
Standard Gear Install kit $75 - SOLD!
TA rear end Girdle cover $150 - SOLD!
243 heads off of a 2009 Siverado 60K $400 - SOLD!
OEM LS6 cam with 53K $100 -SOLD!
Rear GM backing plates with E brake $100
Fine lines SS rear brake lines $25
OEM truck clutch pedal assy. with master cylinder, switch and electrical pig tails for T56 and short brake pedal cover $125
Steering wheel Clam shell for shift lever delete $15
GM 5spd crossmember $100
Front and rear coated Slotted and Cross drilled rotors $150
Corvette servo Kit $50
Buyer pays shipping.
Text 913 five one five 5010 or PM me
Old Oct 9, 2017 | 08:11 PM
z1kman's Avatar
First round of pics
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120142.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120358.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120427.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120620_1507490339034.jpg
Old Oct 9, 2017 | 08:14 PM
z1kman's Avatar
Second round
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121430_1507489878022.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121439_1507489831241.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121215_1507490114400.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121538_1507489813265.jpg
Old Oct 9, 2017 | 08:18 PM
z1kman's Avatar
More pics
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120131-1-.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121233_1507490055472.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121241_1507490021405.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121018_1507490310667.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121021_1507490288927.jpg
8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121404_1507489901351.jpg
Old Oct 9, 2017 | 08:24 PM
z1kman's Avatar
More pics
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121009_1507490324583.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121033_1507490255953.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121039_1507490239383.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_121049_1507490228554.jpg
Old Oct 9, 2017 | 08:28 PM
z1kman's Avatar
Some more pics
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_123744_1507489782803.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_123748_1507489766565.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_123915_1507489713661.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_123921_1507489645607.jpg
Old Oct 9, 2017 | 08:41 PM
z1kman's Avatar
Last set
Attached Thumbnails 8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120301_1507599367826.jpg   8.6 10 Bolt rear stuff,T56 swap stuff, Heads, Cam, Disk Conversion.-20171008_120333.jpg
Old Oct 12, 2017 | 05:48 PM
z1kman's Avatar
To The Top
Old Oct 27, 2017 | 08:54 AM
z1kman's Avatar
To The Top
