6.0 block, 241 heads, ls1 cam, lq9 cam ect
Old 04-21-2013, 12:32 PM
silverado2000's Avatar
Default 6.0 block, 241 heads, ls1 cam, lq9 cam ect
I have a few parts i am trying to sell I am located in north Austin Texas. The prices are very flexible!!!!!!!
2003 LQ4 block 100$
^^^ block had 10,000 miles on it since being bored 30 over. motor ran great tell the thrust bearing went bad and the crank slid around. the crank groved the block some but not to bad. This block as is. i havnt had it checked to see if its still in specs or not i already have another motor. 100$
Mahle forged flat top pistons 10k miles $150 with rods
04 - Mahle PowerPak Piston and Ring Kits
Bore (in)4.030 in.
Bore (mm)102.362mm
Piston Style Flat top, with two valve reliefs
Piston Material Forged aluminum
Compression Distance (in)1.340 in.
Piston Head Volume (cc)+4.00cc
Wrist Pin Style Press-fit
Pin Diameter (in) 0.945 in.
2002 ls1 cam 60,000 miles good shape vatted and clean ready to install $50
2003 ss silverado cam from a 6.0 miles unknow looks good though $50
2002 241 heads 60k miles with springs $150
Old 04-21-2013, 03:08 PM
dane1586's Avatar
pm sent
Old 04-21-2013, 05:47 PM
06SLOZ71's Avatar
What is the specs on the ls1 cam?
Old 04-21-2013, 11:06 PM
197/207 .467/.479 116lsa it is just a stock ls1 cam
Old 04-22-2013, 05:06 PM
Old 04-22-2013, 05:07 PM
Old 04-22-2013, 05:10 PM
Old 04-22-2013, 08:46 PM
Block and pistons sale pending.
Old 04-23-2013, 09:37 PM
vicalma03's Avatar
Whats the word on the pistons?
Old 04-23-2013, 11:41 PM
Someone is suppose to meet me tomorrow to buy them. If he dose not call ill let you know.
Quick Reply: 6.0 block, 241 heads, ls1 cam, lq9 cam ect
