43lbs direct fit injectors
Old Dec 30, 2006 | 05:36 PM
valsperformance's Avatar
Banned
Default 43lbs direct fit injectors
Set of 43lbs. direct fit shorty injectors w/ low miles. Upgraded to 60's for stroker and large turbo. $290 plus shipping.
These injectors are direct replacements for the late model 4.8, 5.3, 6.0, and 6.0 liter truck engines. They flow 43 lbs/hr of fuel @ 58 lbs of fuel pressure. The resistance of the injector is 12 ohms and they will flow at pressures up to 72 psi. These are the perfect injector for trucks with superchargers or built engines. These injectors will support up to 535 HP on a V-8 engine.
Multec™ 2 is a new generation port fuel injector designed to meet the most stringent worldwide application requirements in passenger cars and trucks. It is suitable for any gasoline-alcohol mixture, on two- or four-valve engines. It is small, facilitating improved spray targeting, packaging, and crash protection. It is quiet, eliminating the need for supplemental sound deadeners. World-class durability, linear range, and tight flow tolerances minimize engine out emissions throughout the vehicle’s life.
Multec 2 is suitable for any application requirement up to 6 grams per second static flow and below 2 milligrams per pulse. Internal and external air assist options are available to supplement an extensive variety of spray geometry options.
The Multec 2 injector has lower mean tip leak rates than current injectors. It is optimized for saturated switch injector drivers, which lowers controller cost. The wide linear range enables a single injector to fit multiple applications.
**NOTE: You will need to recalibrate your ECU if you upgrade to these injectors.
Old Jan 1, 2007 | 12:09 PM
Banned
T.t.t.
Old Jan 4, 2007 | 09:50 PM
Banned
t.t.t.
Old Jan 6, 2007 | 03:14 PM
Banned
How about $225? Anyone.
fillpot
Sep 19, 2015 09:10 PM
tito green
Aug 14, 2015 06:01 PM
Aboss
Aug 11, 2015 09:05 AM
Denali08
Aug 9, 2015 04:34 PM
Sexyrado327
Aug 2, 2015 04:08 PM
