212/218 Low Lift NIB, springs rods gaskets oil pump LS2 chain
EDITED, SOME PARTS SOLD - ONLY THING LEFT IS CAM & SPRINGS, $410 SHIPPED, FIRM!
I got some parts rounded up for my LM7, then traded the truck before they were installed. I did install the springs and pushrods for about 1000 miles before taking them out when I traded it away. All parts were purchased from Scoggin Dickey, part numbers listed are for Scoggin Dickey website.
$620 shipped for everything.
$560 shipped for cam, springs, rods and gasket kit.
$100 shipped for oil pump and timing chain. (SOLD)
Comp cams XR265HR-14 54-412-11 212/218 Low lift cam (New In Box)
GM LS2 LS3 LS6 Valve spring set (16) part 12499224
Manley performance parts 7.400 LS1 pushrods (16)
Cam install gasket kit for GM LS engines, includes water pump gaskets, front cover gasket, front cover seal and a new balancer stretch bolt. Does NOT include the valve cover gaskets, all included gaskets are New In Box.
GM LS Engine Oil Pump part 12586665 (New In Box)
GM O-Ring Seal (Red) for LS Oil Pump pick-up tube part 12584922 (New In Box)
GM Performance Parts HD Timing Chain for LS engines part 12586482 (New In Box)
I know most of the guys on here are already into "the game" but my intent with this (other than get rid of my extra parts) is to provide a cheaper package for a new guy to fix up his higher mileage genIII motor. All you need is some intaller parts and you got a good package here. The cam can be ran with a stock converter and doesn't require headers, although both would help of course.
So.. I'm going to try and not break up the cam, springs, rods and gasket kit, at least for a while. If it never sells, then maybe I will.
To make it better for the guy who needs a starter kit, I can do $625 shipped for the whole lot (cam springs rods gaskets oil pump o-ring timing chain). Just the cam+springs+rods+gaskets price doesn't change though, still at $575.
