10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies
Old May 3, 2014 | 06:28 PM
Johnmaster's Avatar
MASS seller approved
Default 10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies
99 Silverado 1500 Axle is complete as a bolt in with caltrac traction bars and 3 leaf spring packs. 390 ring gear and Eaton posi were just professionally installed by Kodiak here in North prairie less than 1000 miles before the motor blew up. New seals, bearings the whole ball of wax.
Brake conversion was done using a bracket and ‘90 k1500 reg cab front rotors and calipers to clear 15” drag wheels, very clean and great bias with the stock master cylinder. Rotors have light rust that will clean up with the first few stops, not bad at all.
Housing was blasted and painted as you can see it’s clean. Posi fluid and good gear lube installed.
Caltracs traction bars installed, only have a couple thousand miles on them.
Wheels are diamond racing steel spoke 15" wheels, Mickey Thompson expensive drag inner tubes, rim screws, ET Drags 28/10.5-15 with better than half life left. Fronts are ET front 28/4.5-15 on Diamond racing steel spoke and tires look like brand new.
Waiting for a Local pick-up. If they don't sell in a few weeks I will consider shipping options.
$1200 complete axle assy
$1000 for drag slicks and skinnies
or $2000 for everything.
Old May 3, 2014 | 06:40 PM
Johnmaster's Avatar
Photos
Attached Thumbnails 10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-img_0769.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-img_7095.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-img_7096.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-img_7099.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-img_7126.jpg
Old May 3, 2014 | 06:51 PM
Johnmaster's Avatar
More Photos, Wheels were custom ordered to center in the wheelwells, fronts ordered to clear calipers, kind of tricky for 15" wheels.
Attached Thumbnails 10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-rimg_0592.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-rimg_0593.jpg   10 Bolt 3.90 Eaton Posi Rear Axle, Caltracs, Slicks & Skinnies-rimg_0595.jpg
Old May 7, 2014 | 10:32 AM
Johnmaster's Avatar
Bolt on go fast parts, ready to rip!
Old May 12, 2014 | 07:56 AM
Johnmaster's Avatar
Bump!
Old May 14, 2014 | 10:08 AM
monchis's Avatar
so u just switched out rotors and calipers and everything bolted up?
Old May 14, 2014 | 12:16 PM
Johnmaster's Avatar
Made custom 3/8" steel brackets, hat rotors from a 90 k1500 front fit like a dream, calipers for the same application bolted right onto the custom brackets. I ran a 1/4" wheel spacer at the track just to be positive the tire valve would clear the caliper. Clean set-up.
Old May 14, 2014 | 01:20 PM
calboi's Avatar
consider selling just the chunk ???
Old May 14, 2014 | 08:06 PM
Johnmaster's Avatar
What is a chunk?
Old May 15, 2014 | 12:56 AM
kelsey_canard's Avatar
How wide are the rear rims?
