are the z06 injectors better than a 5.3injectors
Old Nov 5, 2007 | 09:16 PM
xdanny510x's Avatar
Default are the z06 injectors better than a 5.3injectors
cause im bought to buy a ls6 intake manifold off a member from a different forum and hes sellin it with the z06 injectors that are 28lbs i think are these better than ours???????
Old Nov 5, 2007 | 09:22 PM
kbracing96's Avatar
They're a little bigger, but a different style, nothing better or worse then truck injectors.
Old Nov 5, 2007 | 09:49 PM
Thunderstreak's Avatar
Banned
To use those injectors you will need a retune along with a different fuelrail. Those are nice injectors for a bolton combo using the LS6 intake. If you could find a Ls1 fuel rail to go along with those injectors do it.
Old Nov 5, 2007 | 10:11 PM
xdanny510x's Avatar
yea i seen some ls1 fuel rails from blue scorpion or some **** like that that i seen looked awsome but yea do i need different pigtails as well????
Old Nov 5, 2007 | 10:12 PM
Banned
Yes when using that style injector you will need to splice in those pigtails.
Old Nov 5, 2007 | 10:18 PM
xdanny510x's Avatar
were can i get some pigtails??
Old Nov 5, 2007 | 10:20 PM
Banned
Could go to a Pick-n-Pull and look for any modern EFI GM, Some fords use them or you could simply buy them new
Old Nov 5, 2007 | 10:22 PM
xdanny510x's Avatar
the pigtails have to be off the gm ls1s right?? wtf fords use same pigtails??how much do they usually run about/?
Old Nov 5, 2007 | 10:27 PM
Banned
Any modern EFI that uses a EVO1 injector. The name might be off some. Mustangs, Explorers, Grand Ams, TPI fbodys, LT1 Fbodys, Vettes, 4 banger S10s and etc. The price for new is around 50, Pick-n-Pull probably alot less especially if you cut and not tell
Old Nov 5, 2007 | 10:33 PM
quicksilverado's Avatar
You can get the pigtails from Nelson porformance>>>>>>>>. They are a sponser. They are about $5.00 each.
